Use something like a Chromecast, Amazon Firestick, Roku, PS4 or other Netflix compatible device. Attach it to your TV via the HDMI input and then you can stream NetFlix (and more) to your TV wirelessly.
Netflix
Testimonial: "Thanks a lot. I ordered the Amazon Fire Stick. Appreciate your help"
SOURCE: moving tv to another cable outlet
I f you have cable at the new location follow it back to a splitter. Remove the one you used to use and screw in the one you want to use. They should all terminate at the same location.
SOURCE: Moving desktop across room where there is no cable connection.
you can buy a cheap USB wifi adapter and connect the desktop wirelessly just like your laptop, this should do the trick.
or you can buy an access point to extend the range of the wireless network, you should not be moving the router itself this way.
SOURCE: moved xbox to another tv in another room connected
This is a problem that seems to be coming from your lan cable or router. The best thing you do is to get a sure connection(maybe connected with a pc you know is working)and see if it works. If it doesn't, the fault should be from the router
SOURCE: i neid go know how to reprogram one of the
jc4lifes3as
I have provided instructions on how you can program your remote to your TV.
Without knowing the brand TV you have, I have provided a link with the codes you
can try.
Program to TV:
Remotes: Basic (Television Only)
1. Turn the
Television On.
2. Press and hold the TV Power button for three seconds until the
LED flashes.
3. Enter the three-digit code using the buttons on the number pad.
4. Press OK. Note: The LED will flash three times.
5. Test functionality with
the TV.
6. Return to Step 2 if the remote is not able to turn the TV On/Off,
change the volume and mute the television.
Power Scan:
Remote: Basic Remote
(Television Only)
1. Turn the Television On.
button for three seconds until the LED flashes.
3. Press and release the TV
Power button.
4. Press and release the Up or Down Arrow on the remote until the
television turns off.
5. After the television turns off, press and release the
OK button.
6. Test functionality with the TV.
7. Return to Step 2 if the remote
is not able to turn the TV On/Off, change the volume and mute the television.
The link for the remote codes are at the bottom of the page. Select your
receiver type and then your TV brand to get the codes.
http://www.dishnetwork.com/SupportSection/remote-setup
I hope this helps.
Ray
Calo
DISH Network"
Yes. Just be sure to arrange the cord so that people don't trip over it.
Hi Ceil Lavan, which cord ?
The ethernet cord ?
if it is the ethernet blue cable cat 5
use a network power point switch to do the ethernet via the power if on same circuit
Thanks
