I have checked the inlet pressure switch that regulates the water inflow and there seems to be no problem. The machine is only linked to the cold water inlet.
SOURCE: Washing machine not filling with water not washing but will empty and will spin
like the anchor idea?, no sorry, this does sound like the water is not getting to the machine, so, when you turn the machine on does it make a slight buzzing noise, if so the fault is no water in the pipes to the machine (from the house), if no buzzing check the solenoids with a multimeter for open circuit (removing the 2 wires first) oh and the plug obviously / replace solenoid if needed, i am sure this will cure your problem, if so rate me please, thank you
SOURCE: Daewoo Top loader washing machine water wont drain...
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
SOURCE: hoover 750L top loader washing machine
I had this problem. I alternated the hot and cold water valves (changing over the wiring) and then hot tap then dribbled instead of the cold. Replacement part i believe is around $35AU
SOURCE: Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
SOURCE: I have a DAEWOO DWF-1150P top loader washing
I have a daewoo top loader washing machine ,,
Mode W/M-DWF-200MP
The power main board does not take the programs to work how should be its olny one program
Yes, they are the same.
Thanks again for all assistance,I will swop them over when I get home and let you know if it works. Be well Shaun
