Can not get it to tape will play videos new put do not no how to tape on a clear tape
SOURCE: Wont Record
Usually when a tape starts to play automatically this means that the tab on the back of tape has been removed to stop others recording over it check the tab little black tab in a recess on back edge of tape if this is missing you can put a bit of sellotape over the whole to blank it off this will tell the video tape is ok to record on.
However if the tab is still in place the try putting a small bit of tape over it also to raise the clearence slightly then put back in video and try to record if this still dont work then the mechanism that detects the tab has failed these can be replace but usuall parts are hard to come by now as they no longer make vcrs any more but let me know ok i can assist you further just check tabs in place even try raising it with a bit of card stuck over tab with tape this might make the tab switch work if it has wonr down abit let me know ok.
As you look form back of tape the tab is bottom left hand corner check its flush with the tape if not use sellotape to repair let me know the outcome ok
SOURCE: sony video camera will not record but will play previous taped t
TO REPLACE THE CCD ASSEMBLY. SOME MODELS ARE COVERED BY SONY WARRANTY EVEN AFTER WARRANTY PERIOD, BECOUSE OF FACTORY FAULTY CCD-S -ASK A SONY REPAIR CENTRE OR LOGIN TO THEIR WESITE GOOD LUCK: KOPASZ
SOURCE: Is there a user manual
There is not a "free" manual that for download. However, you can try contacting Hitachi with below information:
For resources and product support on UltraThin1.5 TVs, Projection TVs, LCD Projection TVs, Plasma Televisions, Professional Plasma Monitors, DVD Players and Camcorders, please contact 1-800-HITACHI (800-448-2244).
Email us at: [email protected]
Write us at:
Hitachi America Ltd., Digital Media Division
P.O. Box 3900
Peoria, IL 61612
SOURCE: how can i get a
http://www.brothersoft.com/downloads/computer-manuals.html or this site will tell you how to use something hope this helps
you will have to type in the motherboard in the top search tab
