Magic Chef CAV2000 Top Load Washer Logo
Posted on Jul 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Magic Chef 20lbs hd won't agitate
Older top load Magic Chef 20lbs washer will not agitate. All other cycles work fine.
Anonymous
Level 2:
Sergeant:
  • Expert 187 Answers
  • Posted on Jul 23, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
187
Questions
0
Helped
97060
Points
558
Try these
  1. Test the lid switch
  2. Inspect the motor coupler
  3. Inspect the drive belt (belt drive only)
  4. Inspect under the washer for soot (clutch)
  5. Test the motor
  6. Inspect the pulley
  7. Test the transmission
  8. Inspect the agitator
  9. Inspect the pump coupling
  10. Test the water level switch
pls rate my suggestion.......
Will not spin on spin cycle
That is a single belt driven washer built by maytag. Check the lid switch for propah operation. If it is fine tip the washer back do an inspection of the beltthemobilian_2528.jpg
Check the pump for tightness sometimes they lock up or get something in em. If that is fine turn the main drive pulley and see if it releases the brake and lets the drum turn easily. One direction it locks the tub and agitates and the other direction is pumps out the water and spins.
Manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Margic Chef washing machine makes loud ginding noise when agitating and on the spinning cycle.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Water problem
Magic Chef Clothes washer model CAV2004AWW
Something locked up on the transmission then the drive belt broke. Put on a new belt and try a spin cycle, if it works but it won't agitate then the trans will need replaced.
Flooding Washer
the solenoid needs to be replaced.
MAGIC CHEF 5 YRS OLD WONT AGITATE
Ours started doing the very same thing. I took the top off and found that a mouse had chewed a hole in the vacuum tube. I replaced it with a 3/16" ID small engine gas line hose I bought at local implement dealer. Works like a charm.
tjn
3helpful
Magic Chef CAV2005AWW makes a noise in agitate cycle
Sounds like a problem in the gear case. This would be a transmision replacement.
Top Magic Chef Washing Machines Experts
Paul Carew
Kolbrun...
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
