Watches Logo
C
Christelle Jacobs Posted on Mar 05, 2017
What do the three dials on a fossil chronograph watch mean and how to set them? One at 12 o'clock (6,12,18,24)and 1 at 9 o'clock (10,20,30) and one at 6 o'clock (15,30,45,60)....?
Fossil chronograph watch fs4758 5atm
5 Related Answers
Anonymous
  • Posted on Feb 21, 2009
SOURCE: Instruction Manual for Fossil Watch
-> Go to fossil.com
-> Customer Care
-> Product Info / Watch Instructions
-> Do a mouseover on the various headlines to see the design of your watch.
-> Download desired PDF file
Problem solved. Thank you!
Anonymous
  • Posted on Mar 24, 2009
SOURCE: Fossil Watch Chronograph Problem minute counter resets to 59 instead of 60
1. Pull out the time set mode button.
2. Press the upper right button repeatedly until the sweep hand makes it back to 00/60.
3. Press the time set button back into normal position.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jul 31, 2009
SOURCE: i cant work my watch
here:
http://www.fossil.co.uk/webapp/wcs/stores/servlet/ContentView?langId=10&storeId=32553&catalogId=20002&page=instructions
Rate me, please
small6363
  • 18429 Answers
  • Posted on Oct 25, 2014
SOURCE: I buy a new fossil watch fs4552 chronograph.....
JUST WIND IT FORWARDS 12 HOURS
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Dec 26, 2014
SOURCE: what are the three dials on the right side of my fossil watch for and how to use them?
http://www.fossil.com/wcsstore/CommonFossil/attachments/watch_instructions/Fossil_Watch_Instructions_ENG_UK.pdf
3helpful
2answers
I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
3helpful
I have a sport watch fossil CH2470. the second hand is not moving, stuck on 12, but everything else works. how do i fix this?
Your watch is Chronograph watch and the big centre seconds hand is for chronograph function only - not day to day seconds counting. Check the small dials and you will see that the small seconds hand is already counting seconds- this small one is seconds counter. To engage chrono hand push the upper push button once. To stop it - push the same button again. to return to zero- push lower button. For users manual use this link: http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html Rate me, please.
How do i set this thing? and what do all the dials mean?
If you go to the Fossil web site http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html
You will find a list of diagrams and associated instructions. (As you run the the curser over each model the picture changes to show the layout of the wach the instructions are for).
I could not find the model you mentioned but there must be one of these that is close to yours.
6helpful
The dials on the watch mean what? Do I have to
Go to Fossil.com, choose your area and then go to the bottom of the page.
There you will see "customer care", click on this and on the next page you will see a menu on the left.
Choose instructions and you will then see a list of sketches with watch types (generic)
It may take some searching but you should find what you need here!
1helpful
How do i use and set my fossil ch2589
You can get instructions for your watch from the Fossil web site.
Go to "fossil.com", go to the bottom of the page and you will see a menu, click on "customer care", and then look under "Product Info" on the left and you will see "watch instructions"
Click on this and a list of diagrams and watch descriptions will appear,Download the file that is suitable for your watch.
2helpful
HOW TO WORK THE SUB DIALS
This is an Architect Chronograph. To start the chronograph press the top start button. To stop it press it again. To reset it press the reset or bottom button. The sub dials are minutes, hours, and seconds.
20helpful
2answers
Oct 01, 2008 • Watches
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
