Epson WorkForce WF-3640 Wireless Color All-in-One Inkjet Printer Logo
L
Linda Field Posted on Mar 04, 2017
Brand-new Epson WF 3640, need to print copy of a document that I have put on the glass screen. I'm not using the auto feeder right now. I've hit 'START' for B&W copy and it says operation is invalid.
1 Related Answer
ivars_vitins
Ivars Vitins
  • 29 Answers
  • Posted on Sep 24, 2015
SOURCE: How do I use top feeder on Epson WF-3640?
Download manual from link http://failiem.lv/u/oqcbkkq It will be available 1 month. In pdf. file see page 86 and 228 how to print more than 1 page.
4answers
3answers
WOT DOES ADF MEAN ON MY EPSON WF-2630
ADF is an outomatic document feeder on top of the printer. That's where you put paper that you want copies or scans of. See video below.
2answers
Why does adf cause line in center of printed documents?
Usually needs a cleaning of glass. See video tutorial. It's on a different printer, but same concept:
2answers
When I try to make copies using the ADF the screen tells me to remove documents and place on glass.Can you explain why. I have sveral pages
Automatic document feeder requires you to insert files into holder and let the machine scan through the pile providing you have not over ridden settings to manual.it sounds as if you have switched off adf to manual which would require you to place each document onto glass one at a time.see if you can switch it back to auto in the screen menu.
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
1helpful
Lines on copy's when using auto document feeder on epson artisan 800
You don't say exactly, but I'm guessing that scanning when laying the document flat on the glass (ie, not using the document feeder) you get a printout that is fine. It's only when you use the document feeder that you get the vertical lines on the printout?
Epson repair tech in my area says this is a common problem. It is due to the aging of the calibration strip (the white strip at the underside of the flat bed glass near the "home" position). It shrinks after years and can't provide correct calibration.
This is a problem only with the pages fed through the document scanner. It sounded weird to me, but the tech said he stocks lots of replacement glass and does lots of these repairs to Epson scanners.
It might be cheaper to buy a new scanner rather than get yours fixed. He said it's pretty inexpensive to do this repair, but scanners are also pretty cheap.
Good luck.
1helpful
Auto Document Feeder copier problems
The scanning glass probably needs cleaning.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
