Vizio tv power board 0500-061400280 and main board 3650-0112-0150 2E schematics and diagrams available?
I have a Vizio TV model E500i-A0 with power/LED Driver board 0500-0614-0280 and main board 3650-0112-0150 2E ser# LAQLNTBP3500360 which powers on then blue indicator LED fades to off no standby LED on at all. The LED strings 1 and 2 flash on for 1/2 second and off for 2 seconds. pic flashes on/off with back lights. need to know where test points and componenets are on boards
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Command voltage to switch ON the LED driver section, should come from the main board's system control section. It do not come now.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
If the remote wasn't working you should be able to turn it on with the on button, is there any indicator lamps that light or flash or is it like its unplugged?
This is not a fault with its remote control. The main board to your TV should be checked. Contact any service technician. If you wish to get more details, check the site linked here. http://electronicshelponline.blogspot.com/
