You didn't specify model of your washing machine.
For Electrolux that usually means water leaks (Maximum overall water fill time exceeded (sum of all water fills between one drain phase and the next to avoid exceeding the maximum volume).
Could be:
Drain tube improperly positioned; Water pressure too low;
Water fill solenoid valve faulty; Water circuit on pressure switch is
leaking/clogged; Pressure switch faulty.
Dado
SOURCE: Error code E10 on the
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
SOURCE: e13 error code with my
I had an E-13 error code on my Bosch 500 series washer. The drain pump impeller was plugged. Access the drain impeller at the bottom front right corner. Just put a pen in the hole and turn the cover. Then you need to manually drain the washer. I used a shop vac by just turning the cap until it started to leak and vacuum the water as it comes out, this takes quite a while. When you get it drained you can take the cap completely off. When I did I found a wipe in the impeller. I took it out and put it back together and the washer worked just as before. Good Luck!!
SOURCE: Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: e13 code, monitor 2400
You have an obstruction in your fuel line. Lint or rust or some other debris, either in your main fuel filter which I hope you have or in the small one in the fuel sump on the lower right hand side (the little square hole below the round finger hole for the reset button). The screen is cleanable with air or brakekleen or both. Or it might be that your Constant Level Valve is tripping or has tripped. Push the button in the round hole on the lower right hand one time quickly (don't hold it down or press it several times slowly) and you should hear the float drop. Fuel should resume flowing to the fuel sump at that time.
Hello Mark Depner - Typically error code E13 indicates that the washer is detecting a water leak in tub or air leak in air bell. You will need to contact a professional to move forward accurately and verify where the leak is located.
