I have a saeco super automatica. When I turn it on the brew unit starts and it goes thru the cycle to the hot water dispenser for only a few seconds. Then it goes back to the home position. After this the water comes out of the hot water dispenser and Leaks behind and below the brewing unit. Thankyou
Take the brew unit out when the machine is off and cold. With your finger, check the well next to the large gear on the inside of the machine. This is the gear that fits in the back of the brew unit when it is in place. That well may be clogged with fine coffee grounds and some mildew build up. You might notice that after brewing, very little water will has been flowing into the drip tray. Take a Q-tip and push it through the hole at the bottom of the well to remove the coffee ground buildup. The excess water after brewing will flow through normally now and not behind the brew unit.
