Contact your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
SOURCE: Pull cord on TB25CS trimmer came out all the way, won't recoil
http://www.m-and-d.com/pdfs/MTD/TB25CS-41BDT25C063PL.pdf
Probably the recoil spring is broken.
SOURCE: broken recoil spring
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool.
Both methods require about 2 turns of pretension to rewind the cord when pulled.
Lou
SOURCE: Starter recoil spring reload, How?
If the spring is unwound.
Recoil Spring Rewind
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If the starter cord needs a pretension, this works quite well.
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
SOURCE: How do you re-install recoil spring
Possible answer 1 (a very good description of tension adjustment is on the video in answer 2; about 1:20 into film):
Possible answer 2:
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
SOURCE: replace recoil starter for Homelite trimmer Model UT21546
My UT21546 has 2 springs, the regular recoil one and a what I'll call a anti kickback one. the top of the anti kickback spring kept coming unsecured and finally I just deleated it alltogther and screwed the 2 plates tightly togehter and the near new unit works better than new now.
