Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Keep it in case you want to go back to the bucket.
Also, make sure the unit is higher than the drain and that the hose is not kinked or clogged.
Please rate 4 stars if this is helpful. Thanks and good luck!
