SOURCE: Call forwarding to outside line
To send a call to another telephone within your system, or to an external
telephone. You may not be able to transfer a call on an external line
to an external telephone, depending on the capabilities of the lines.
1. Make or answer a call.
2. Press the feature button then press 70.
3. Call the person you want to transfer the call to.
4. Stay on the line if you wish to speak to the person first.
5. Press the Release button to complete the transfer.
If an external call is transferred to a busy internal or network
extension, or is not answered after a few rings, the call automatically
rings you back.
SOURCE: Norstar m7324 - forward to outside line
The solution for someone using the administrator phone (receptionist phone) is after discovering you have a fax call, depress the <link> button. Dial the fax number, wait for it to answer, then depress <link> again. This places call 1 with an outside number.
Apparently this is also available if you have a feature button by depressing <feature> <7> <1> instead of <link>. I haven't tried this so don't take my word for it.
This can also be used to forward a caller to an outside line, such as a cell phone. In the manufacturing business, our shop manager is never in the office. I may ask him if this is a viable solution.
SOURCE: How do I retrieve recent incoming calls
If you have call log set up you can access the log log by pressing feature 812. To program that feature as a one touch button press feature *3, press the button you what to be call log and enter feature 812
SOURCE: Norstar 7324-two lines show in use, but wont hang up
Power cycle the system. You need to go into lines/trunks and change the line typ from unsupervised to supervised so this will stop.
SOURCE: Norstar Meridian M7100 incoming calls - no ringing tone
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
