SOURCE: Canon LBP-2900 Printer Open top
It is very easy to open the printer.First you need to remove the screws at the back.Then slowly remove the white panels which is fixed at the left and right sides.You should be very careful doing so,because there is no screws instead of that only plastic locks.Then you can remove the top cover.The total plastic panel you can remove only removing the two screws.Best of luck
