Question about Health & Beauty
Browning BPR 22 mag has bent mechanism housing so scope doesn't line up. Can I heat it below barrel bush without removing barrel and press?
Worried about scale, pressing too far and temper - metal is thin and barrel fit critical.
  • 2,195 Answers
No it would be a very bad idea unless you are willing to take the chance of turning it into scrap metal
take it to a gunsmith for a inspection and repair quote if possible
Posted on Feb 28, 2017
Testimonial: "Thanks. Of course you are right. But that's what it was having been run over by a truck from end to end and I have got it to this point - beautiful but doesn't eject or fire occasionally and scope zero doesn't hold long although its got an old scope while mount is out 5 mm by barrel end and I wanted to work through again from basics."
SOURCE:
Tip
Simmons 3*9 22 MAG scope
I bought one SIMMONS 3*9 MAG 22 riffle scope from USA last month in $54 and fixed it on my .22 riffle with proper instruction. When I shooted 2-3 bullets, its + sign is moved from actual target.
I made the target and + again in sync and after shooting 3-4 bullets, its + changed the position. After consulting with some mechanic, he told me the SIMMONS telescope is manufactured in China and its acuracy is not upto the mark. He was advocating me to buy bushnell scope for my riffle.
Now I am confused and not able to identify how to fix this + movement problem in my scope.
Can anyone please help me on this ????
Your reply is very much anticipated.
Thanks !!
on Aug 12, 2008 | Simmons Outdoor Blazer Matte (4 x 32mm)...
BROWNING ARMS .22 Auto with 5 inch barrel, great condition. Believe it was manufactured in 1965. How much could this sell for?
sadly we do not appraise guns here . take it to a gunshop local to you and ask them
Jan 16, 2016 | Optics
Looking for browning 22 automatic used
pawn shop, new paper, look up used guns store, craig, list, and or back page. local sporting goods store, gun smith, gun restoration,
online.com, www.cheaperthandirt.com/
www.galleryofguns.com/
www.jgsales.com/
www.cdnnsports.com/
www.sarcoinc.com/
www.e-sarcoinc.com/
most of the time you buy it cheap at these site than online or stores
some times you can buy a new 22 at these sites cheaper that buying used one best of luck rod
Feb 20, 2015 | Browning Semi-Auto Grade I 22 L.R. 19.25"...
Browning rifle .22-.250. sn 11107z8. does not fit typical browning code ,any help?
I like using armslist.com to see what firearms are going for. This will give you a good gauge.
Sep 21, 2014 | Optics
Do they make a trigger kit for a pk380?
Not sure what you mean by "trigger kit", but if you mean how to reduce the lbs of trigger pull, several companies off spring kits.
Here's an example:
http://www.midwayusa.com/Product/177318/wolff-hammer-spring-pack-walther-ppk-s-reduced-power
Jul 01, 2014 | Browning Bar Mark Ii Safari .243...
What is a browning bar 30-06 worth
By your serial number this is a 1968. Without knowing it's condition it's impossible to say. Does it have the engraved Deer in steel receiver, genuine walnut stock and forearm with diamond pattern cut checkering? So many things to consider. I would just take it to your local dealer and ask for a written appraisal. Sorry I couldn't be of more help.
Jun 19, 2014 | Browning Bar Mark Ii Safari .30-06...
Browning BAR fires a round reloads next round but will not fire it. no firing pin hits on primer of 2nd shot
Check that the bolt is completely closed/engaged. If you are using reloads run them through a checker to see if they are sized correctly.
Sep 15, 2013 | Warne Browning BAR Barii Mark II BLR...
Loss of focus when izoom in
This typically means that you are have exceeded the scopes ability to focus at the distance that you are shooting. This scope is optimized for 50 yards and will function well at all magnification settings. Closer than this optimal distance the higher magnifications may present problems with blurring. Many scopes have a "parallax" adjustment that changes the optical focus to correct this problem. Several of my 22 mag scopes have this adjustment on the objective bell. You simply set the indicator line on the appropriate yardage indicator (making minor adjustments to fine tune focus). Hope this helps
Sep 16, 2010 | Simmons 22 Mag 39X32 with Rings
Health & Beauty Logo
37 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
