SOURCE: Reseting Jabra Bluetooth
Jabra headsets sometimes have a different way of being put into discovery mode. Most headsets just have you press and hold the big call button on it. Some jabra headsets require you to JUST hold down both volume buttons and some other jabra headsets require you to hold down ALL buttons on the headset to put it in discovery mode (or pairing mode as they sometimes call it)
Try of those combinations ... The light will stay solid when it's in discovery mode... Once the light is solid THEN have the EnV search for headsets.
hope this helps
SOURCE: Jabra connection
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on. 2. Set your Bluetooth phone to ediscoverf the Jabra BT150 Follow your phonefs instruction guide. This usually involves going to a esetup,f econnectf or eBluetoothf menu on your phone and selecting the option to ediscoverf or eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4) 3. Your phone will find the Jabra BT150 Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing
SOURCE: Bluetooth ear set not being detected by new phone
ok, thanks.
Found the problem. As always "Read the instructions first!"
Bye
SOURCE: setting up Jabra VBT2050 Bluetooth
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
SOURCE: unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
You can solve this by connecting your phone inline.
On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
