Https://docviewer.yandex.ru/view/0/?*=pQL6oAfMaJdYXVCFtA2Z0jxduzN7InVybCI6InlhLWRpc2stcHVibGljOi8vV3EzL0t3Mk4wUm8veERUbGRMbllZZDJrckhRWElEbFlicFp4MlVZaUpyTT0iLCJ0aXRsZSI6IlNoYXJwX0FSLTU3MjZfQVItNTczMV9TTV9QQy5wZGYiLCJ1aWQiOiIwIiwieXUiOiI4NDQyNTg2MTUxNTM0OTM2NjAwIiwibm9pZnJhbWUiOnRydWUsInRzIjoxNTQ3NzIzMTk1NDk4fQ%3D%3D&page=98&lang=ru
weird website, but has extremely detailed manual.
SOURCE: Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
SOURCE: sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
SOURCE: Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
SOURCE: sharp AR-R550n
Hello sir; You may try to perform a reset procedure as follow;
press " program", " * ", " clear ", " * " and start key, then enter 17, press start again, turn machine off and back on.
