Car Audio & Video Logo
DO IT BIG Chevy 1995 Posted on Feb 28, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need help hooking up a rca converter box in a Lincoln town car carter with the alpine stereo system
Mike Chamberlin
Level 2:
Scholar:
New Friend:
  • Expert 88 Answers
  • Posted on Mar 01, 2017
Mike Chamberlin
Expert
Level 2:
Scholar:
New Friend:
Answers
88
Questions
0
Helped
72957
Points
191
Is the converter powered or passive? Each RCA (red or white) connection represents a + and - speaker wire for one speaker or channel. So assuming you already have the amplifier you'll cut the speaker wire coming from the head unit. From the head unit speaker wires will attach to the input or hi-level connection on the converter. The other half of the wiring goes to the speakers in the doors. Those will go to the amplifier which is or should be fed by the RCA's on the hi-level converter box.
Passive coverters don't require 12v power but active ones will need 12v input from a remote signal such as from ignition circuit or a power antenna to turn the unit off and on so your battery isn't drained with the car off.
5 Related Answers
fordexpert
  • 5692 Answers
  • Posted on May 05, 2009
SOURCE: 2000 Lincoln Town Car (Engine Service) found a EVAP System?
Check your gas cap. If someplace can test it you might luck out. This website advertises manuals and info online. The evaporator cannister is suppose to purify excess fuel vapors. But a system which is not sealed will code an error lamp.
old marine
old marine
  • 2426 Answers
  • Posted on May 11, 2009
SOURCE: need routing diagram for 2000 lincoln town car serpentine belt
There's a diagram at this link.
Anonymous
  • 7 Answers
  • Posted on Jul 21, 2009
SOURCE: wiring diagram
Go to 12Volt.com
They have the best and most complete wiring diagrams for all your makes, model for stereo installation and other wiring problems.
Anonymous
  • 24 Answers
  • Posted on Apr 30, 2010
SOURCE: Need a fuse box daigram and layout?
https://www.fleet.ford.com/maintenance/owners_manuals/results.asp
Pages 126-130
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on May 13, 2010
SOURCE: Need a fuse box diagram for a 2003 Lincoln Town
I suggest check the Lincoln TonwCar owners manual (page 160 and next)...
Hope this help (remember comment and rated this).
1993 Lincoln Town Car. I need amp in truck diagram for it.
Stereo and Speaker Swap in the 1990 - 1994 Lincoln ...
lincolnvscadillac.com https://www.lincolnvscadillac.com > forum > ams > ste...
Apr 19, 2017 - In the trunk of your Lincoln Town Car on the passenger side of the spare there is a black box on the back of the rear seat. It is the amplifier ...
3answers
I have a 1991 Lincoln Town car and I hooked up a stereo system an all at once my locks Windows stereo and air ride have went out I was wondering if you could give me a step by step on how to fix this
Could be to late. Could have blow the BCM. Unhook the radio and see if the other things start working. If they do, your lucky. Then find some to hook up the radio. I can install radios, but I use a volt /ohm meter. You can not trust the diagrams the radios come with. Or the diagrams I buy.
I have a alpine amp i need to install in to my f150 truck with a factory radio
The easiest way to accomplish this is to get a kit from your nearby stereo shop that will convert your stereo signal from your factory unit to a pair of rca outputs .You can get them from walmart if you feel up to the task of wiring it up. You will still need to get an amp wiring kit as well from there its just a matter of running power ground and rca cords also a remote lead to turn the amp on and off-you can do that from the fuse box easy enough.-after that just run your speaker wires from the amp to the speakers and your in business.hope that helps
Car stereo panel lights
try this site
http://www.shareamemory.com/radio/
please rate highly if this helps
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
I cant fugure out where to hook my amp into this cd player.. Its a alpine bmw buisness radio! thanks
IN ORDER TO HOOK IT UP U HAVE TO HAVE A RCA CONVERTER, YOU CAN EITHER HOOK IT UP THROUGH YOUR MIDS OR SPLICE INTO YOU STOCK WIRE HARNESS FOR YOUR STEREO, IN THE SPEAKER WIRES.
GOOD LUCK
2answers
How would i add amp and sub to a factory stereo system
You can't hook it up like an aftermarket stereo, but there is a piece of equipment (cannot remember what it is called right now) in which you can hook regular speaker wire up to it and it converts it into an RCA jack connector.
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
