You can restore your iphone 5c via itunes this will remove any passcode from your iphone but it also delete all data on your iphone 5c. you can also start in recovery mode
for iphone 5c to enter in recovery mode press and hold home and top button or home and side button until you will see recovery mode screen.
you can also recover passcode from system folder but for that you need to have special software which can access your root folder.
Ipad iphone restore without losing data
SOURCE: anyone got code starting 5C 01 18/02 plz?
key0=0B F2 52 72 4E 1B 86 90
key1=83 61 00 3A FD F3 DC 0A
SOURCE: Is there adaptor for iphone 4 jack to use with iphone 5c lightning jack
On eBay there is an adaptor to connect iPhone 4's and iPods to iPhone 5.
SOURCE: Forgot screen lock pattern on my iPhone 5c I need
Yes, you can reset it by holding the power a home key at the same time. If you come up with your password after that, it will be to late. But you can restore it after the reset from your last or latest backup, either on your computer or in the iCloud.
SOURCE: I have an iPhone 5c and I took a screenshot on
connect to pc using usb and then press the power key and the home button together and hold it until you see the usb picture on iPhone. Once its there disconnect usb and try restarting it.
SOURCE: How do I reset to factory a disabled iPhone 5C?
IF the phone is disabled and you don't have access to it, by that I mean you can't setup the phone, the best way to get about this is going into an apple store.
You may plug it into a computer with iTunes on it and try doing a factory reset from there.
