Prefixes and suffixes are grammatical and lingual "affixes." Prefixes are affixed before and suffixes after a base word or word stem to add information. For example, with the word "prehistoric," the prefix is "pre-" meaning "before," the base word is "history" meaning "recorded events and knowledge", and the suffix is "-ic" meaning "relating to the science of."
In other words, "prefix" simply refers to an attachment before or in front of, in this case, a shorter word or stem. In lingual terms, a "stem" is the main part of a word to which prefixes and suffixes can be added and may not necessarily be a word itself, such as "dod" in "doddle."
Similarly, "suffix" refers to an attachment after the end of an existing word or stem, serving to form a new word or functioning as an inflectional ending, for example, "s" or "es" to make for plurality.
This is not a proper question. Are you asking what suffixes does "Adherent" take, or what suffixes does "Adherent" already have?
I believe the answer to both might be "There aren't any." Adhere is a verb. Adherent is an adjective. If you want to pretend that adding "-nt" to adhere is a suffix, then I suppose it would have the meaning of "takes the form of" or "has the properties of." Adhere means "to stick to." Therefore, "adherent" could be "sticky."
Segregation Segregate
"se" is the prefix meaning: "from" or "away"
"greg" is the root of the word meaning "group" or "united" or "union" "tion" is the suffix meaning "result of" or "state of" or "act of" "ate" (for segregate) would be the suffix meaning: "make" or "cause". Hope this helped!
Prefix/Suffix Dialogs The Prefix/Suffix Dialogs allows configuration of DataWedge options. Two data entry fields are used to display and allow entry or editing of prefix and suffix strings. The prefix string, if present, is transmitted before the data for any barcode scanned. The suffix string, if present, is transmitted after the data for any barcode scanned. The following checkboxes are used to display and allow modification of various DataWedge options: Allow escapes in prefix/suffix (default = disabled) Enabling this option allows escape sequences to be embedded in prefix and suffix strings. Escape sequences allow non-textual data to be transmitted as part of the prefix or suffix string. All escape sequences begin with the backslash “\” character. The supported escape sequences are: \b Backspace \f Form feed \n New line (line feed) \r Carriage return
