If you look at HP , HP owns COMPAQ, lock stock and barrel.
you'd see it there, if still there, if not its RETIRED now
zero info there.
that means only GOOGLE can find it, and pure luck.
omg old and useless.
AMD K6 MMX 233 MHz , old K6 PC. wow.
why mess with this beast for $20 at GOODWILL get a $10 old pc with windows, 7 and dont lock back, nah really!
has PATA DRIVES IT SO OLD , OMG.
RETIRED LONG LONG AGO.... WHY OWN THIS.
The shops trash these, and keep the SATA ones, 10 years or newer
https://support.hp.com/us-en/retired-products
ever google before, good luck with relics
here i will type for you. (i boycott google so. use this....)
https://duckduckgo.com/?q=compaq+4540+manual&ia=web
SOURCE: my desk top
Yes, the CMOS battery is replaceable, and easily so. Just remove the old one, go down to an electronics shop, get a similar battery and replace it.
Unfortunately, we just provide online help, and cannot physically come there and do this for you.
Here are two online tutorials that explain the procedure in detail:
http://www.computerhope.com/issues/ch000239.htm
http://www.hardwaresecrets.com/article/81
Hope that helps! And please dont forget to rate this solution as a Fixya if it helped you in any way.
Cheers!
IrishDruid
SOURCE: desk top compaq presario
Shut down the computer--remove all the cables frm tower--hold on the power button for 20 sec and then release it and then plug back the cables and restart ur computer.
When back to desktop---check if u have more than one anti-virus and/or more than one anti-spyware/trojan and/or more than one software firewall program running at the same time.Un-install any similar you aren't using.
-- Uninstall any Programs you don't need anymore .
-- Try Disk cleanup ,disk fragment.
-- Finally if nothing helps.Download a Program Called SDFix and Install it.
Then Restart Your Computer in Safe Mode. (Just Restart Your comp and press F8 Before the Windows Loading Icon)
-- In Safe Mode Your Computer Is Running With the Bare minimum,Open up SDFix folder and click on RunThis.It'll clean up anything you have and Give you a detailed report after.
-- Instal cc cleaner and clean ur computer.
This should fix the problem.
SOURCE: need picture of wiring for compaq presario desk top go for power
For information on technical issues such as this, please email us at: [email protected]
SOURCE: compaq presario 5300us desk top
I suggest you should download this software and run it, find the motherboard model number and get its user manual from manufacturer website
http://www.download.com/Everest-Ultimate-Edition/3000-2086_4-10499291.html
SOURCE: need a free user guide for my compacq CQ60
here is the link to the guide for your computer
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
