Question about Electric Razor Pocket Rocket Ride-on Motorcycle
Razor MX 650 wont run
The charging light comes on, and it seems to charge. I disconnect the battery cable and twist the throttle, but it wont go. I have checked the brake interlock, but it seems fine. The bike only has about 20 hours on it.
I had the same problem but fixed it this morning, i just sat far back on the seat when turning throtle with all my weight and then slid back on normal when moving, but it makes a grinding noise.
Posted on Jun 21, 2010
SOURCE:
I have a 650 razor motorcycle the battery shows fully charged but clicks when I turn throttle but it does runnsometimes
Hello
Before you change the battery check thoroughly all wires and all connections!!!!
Nov 26, 2017 | Razor Toys
Hannah Montana razor scooter says charged but wont go whats wrong
I haven't used my razor scooter in years. I just bought a charger and it seem like it is charging but it keep saying it is on low. I twisted the gas thing and it is making a noise like it want to go. But I am not sure I have charge it for 12 hours now. Do I need a battery or is it just taking it time to charge.
Sep 17, 2015 | Electric Razor Pocket Mod Scooter
MY RAZOR QUAD IS CHAREGED BUT WILL NOT RUN
I have exactly the same problem and it started right around the time the "gracious" 90-day warranty period expired.....
The battery lights had been on for days, indicating a full charge, but nothing happens when turning the throttle. Battery housing is very cumbersome to open, but I'll try to disconnect the battery next.
Jul 22, 2014 | Razor Dirt Quad Bike
My son has a Razor 350 electric dirt bike he was driving it & it just stopped. It's fully charged green light for battery. I chked plugs & battery is good, throttle wires are disconnected how to I...
Disconnected where? If the wire came out of the throttle your hall sensor is probably mangled and you will need a new throttle. Any other damage just splice it. Did the wires come off the plastic connector at the controller?
May 24, 2014 | Cycling
I was given a mx350 that has been sitting in a garage for a year I charged it for 8 hours but it does nothing the light comes on to show it has power but when i turn the throttle nothing no sound or...
If it was working before it sat, then it is almost certainly the battery (these kinds of batteries suffer if sitting and not fully charged). If you had one, or could borrow a voltmeter, you could check the batt. Also, lots of car part places like NAPA can test batteries for you.
Hope that helps
Jul 18, 2011 | Razor MX350 DIRT ROCKET - BLUE
The MX500 wont start. The light says the battery is charged but when I twist the throttle all I hear is a clicking noise. Is it possibly the fuse?
Although you alternator may be charging, the battery may not be accepting the charge or holding it. Have the battery tested under load, but I think that you are going to find you will need to replace it.
May 09, 2011 | Razor MX500 Dirt Rocket
My 1997 650 savage wont keep a charge
Hmm, do you have a voltmeter, check the voltage on the battery with it running, usually 13.5 to 15 volts
If that reads ok, you probably have a short, get a testlight, pull off the negative cable off the battery,clamp one end to the cable and the other to the battery. If it lights up, you have a short, start unplugging stuff until you find the short and the light goes out!
Jun 09, 2009 | 1989 Suzuki LS 650 Savage
Electric Razor Pocket Rocket Ride-on Motorcycle Logo
1,887 people viewed this question
Top Electric Toys Experts
NOEL
NOEL
Lawrence Oravetz
Are you an Electric Toy Expert? Answer questions, earn points and help others
