Kyocera Color Copier, Km-c2525e Logo
A
Anonymous Posted on Feb 23, 2017
When i connect my kyocera km c2525e to the computer its picked as OEM 2JL-25C
Kyocera KM C2525E printer drivers problem
Div wis
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 04, 2020
Div wis
Contributor
Level 1:
Answers
Questions
0
Helped
249
Points
Try networking the printer, but if the problem continues then u will need to provide more details about it
Marius Chiriac
Level 2:
  • Kyocera Expert 242 Answers
  • Posted on Dec 29, 2017
Marius Chiriac
Kyocera Expert
Level 2:
Answers
242
Questions
0
Helped
114245
Points
658
Hello, connect your copier in a network and you can use the drivers from this page https://www.kyoceradocumentsolutions.eu/index/service/dlc.false.driver.KMC2525E._.EN.html
1 Related Answer
Anonymous
  • 66 Answers
  • Posted on Aug 16, 2009
SOURCE: copier km-c2525e will only print 1 page of document
Hi
it might be a long shot but have you got an add toner message on your copier screen.
When toner is required the copier will only print on page at a time.
Alternately you should ensure that you have not selected a partial print  eg
print current view or print current page.
if all this fails, reload the driver and or your Acrobat reader
hope this helps
Kyocera KM-C2525E Yellow cartridge will not load. Message please replace cartridge
Here are some steps I feel you can take to resolve the issue with your Kyocera KM-C2525E yellow cartridge:
Check the cartridge chip - The yellow cartridge has a small chip on it that communicates with the printer. If the chip is damaged or dirty, it can prevent the cartridge from being recognized by the printer. Try cleaning the chip with a soft, dry cloth and reinserting the cartridge.
Check the cartridge contacts on the printer - The printer also has contacts where the cartridge is inserted. If these contacts are dirty or damaged, it can prevent the cartridge from being recognized. Try cleaning the contacts with a soft, dry cloth.
Perform a drum refresh - The drum in the printer can sometimes become coated with toner, which can prevent the cartridge from making proper contact with the printer. Try performing a drum refresh from the printer's control panel to clean the drum.
Reset the printer - Sometimes resetting the printer can clear any issues with the cartridge recognition. Try turning off the printer, unplugging it from the power source, and waiting a few minutes before plugging it back in and turning it on.
Replace the cartridge sensor - If none of the above steps resolve the issue, it could be due to a faulty cartridge sensor. The sensor detects when a cartridge is inserted and communicates with the printer. You may need to replace the sensor to resolve the issue.
How can fix the error message c7104 in Kyocera c2525e
this code is saying you have a bad yellow dv unit you have to have a new 1
C2525e touch panel not working
Run a business card between the touch screen and the outside surround. Dirt or dust can make the screen believe that you are constantly touching the screen which will lock up the touchscreen. Try adjusting the screen brightness by adjusting the thumbwheel located at the far top of the display panel.
If this does not rectify the fault then the touchscreen will need to be replaced.
System error c0430
make sure RADF is connected
Print job stuck on the queu and dont print
look at bottom R of PC if the printer Symbol is there double click to open. Cancel all jobs, nothing will print if jobs are stuck. Once sleared try going to START -- SETTINGS -- Printer -- the one you are printing fromand right click on it. It will open up a window, go to properties and try printing a test sheet. if it still stays in queue, there is a problem with settings. Do you have more of one of the same printer then try the other one if it prints then delete the one not printing; or delete and reinstall driver.
1helpful
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Copier km-c2525e will only print 1 page of document
Hi
hope this helps
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
