Question about Bulova Watches
I received a Bulova watch from Amtrak when I retired 6 years ago. I need to know how to obtain additional links for the band? I believe the model number is C960600.
    Top Expert:
  • Bulova Master
  • 28,974 Answers
My father was William Taylor!
Last retail price on that watch was $40!
https://www.buya.com/Model/Details/BULOVA-C960600/d9a6e7562c9a4bcfbbe43e281e0b3d8b
These will try and sell you new bands.
https://www.google.ca/search?q=Bulova+watch&ie=utf-8&oe=utf-8&gws_rd=cr&ei=9SSuWN-OA6m3jwT6noi4Cw#q=Bulova+watch+strap+links
Your best bet is to contact Bulova direct using the link at the bottom of the page.
Precisionist Watches and Chronographs
Posted on Feb 23, 2017
SOURCE:
SOURCE: How to remove links from Fossil metal band?
I've had a Fossil before, but forgot how easy it is. Thanks for the refresher.
Posted on Jan 14, 2008
SOURCE: Armitron mens watch band link removal
Try http://www.webjeweller.com/jewellery/removelinks.shtml
Posted on Jul 14, 2008
SOURCE: i need to add 2
Contact Bulova for additional links, 800-233-3350. You will need the watch model number and the case number (it's in the back beginning with "C".
Posted on Aug 20, 2008
SOURCE: Remove links from metal watch band
This was on a Seiko Dive watch SKX007. This has the metal links joined with pins, which, you will find, are split/spring down their length.
I used a neoprene mouse mat as a work surface, which was ideal as it allows the pin to move out, whilst supporting the links and stopping any slippage. I also rigged a table lamp close by.
There is an arrow which shows in which direction the pin needs to be pushed to remove it. Look carefully and you see that one end of the pin is slotted a little, the other is plain. Push the plain end in the direction of the arrow firmly... it's a leap of faith.
As a tool, I used a cocktail stick to start with. It required firm pressure and then it suddenly gives. I was able to draw the pin out by hand, but used pin nose pliars in one instance, as some pins offer more resistance than others. In most cases the cocktail stick worked (I got through a few). I then graduated to a thumb tack which was more reliable, but metal to metal, so a bit more worrying.
Sliding the pin back was simple, though take care to get the smaller links the right way up when it is re-threaded. I pushed it home the last few millimeters with the flat side of the pliers, giving a final push with the cocktail stick. Good luck. Simplysimon.
Posted on Oct 01, 2008
escapement
  • 2338 Answers
SOURCE: remove links from fossil metal band
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 07, 2009
I need a replacement band for C96912611A 18194281 Bolva (Bulova?)
I think you mean 'Bulova'?
Those numbers don't seem to be correct, but there is a link to Bulova here and replacement bands advertised.
replacement band for C96912611A 18194281 Bulova Google Search
Jul 25, 2018 | Watches
Where can i get links to add to band or replace band?
Parts Archives - Citizen Watch - English (US)
www.citizenwatch.com/en-us/faq-category/parts/
Citizen HoldingsQ: Why can't my jeweler or I order parts for my watch that is marked 'factory ... We domake some components such as bands and band parts available directly. ....Determine how many links of this size are needed to make the watch band the ... Q:Can you use substitute parts if the replacement part I need is discontinued? A:.Missing: timberland
How To Easily Remove a Watch Link - YouTube
? 3:10
https://www.youtube.com/watch?v=8uxpDXKOPqA
Dec 29, 2011 - Uploaded by TheBiggerKid
I got a watch for Christmas but the watch band needed a little adjusting. I thought ... Real Men Real Style 310,589 views ... How To Resize A Citizen Watch Band - Add & Remove Links At Home ... Get video URL at current time.Missing: timberland
Your Guide to Adding and Removing Links in a Bulova Watch
www.ebay.com > ... > Jewelry & Watches > Watches > Wristwatches
If the current watch does not fit properly, find another watch, a bracelet, ... When a metal watch band is too small, add links to make thewatch band ... How to Choose the Right Strap Replacement for... ... Bulova Men's 98E112 Diamond Set Stainless...... Bulova Men's 96A28 Black Leather Band Quartz Watch NIB Image ...
Jan 31, 2016 | Timberland Mens Quartz Watch Qt7117302
How do I open the band?
How to adjust your watch band - YouTube
? 7:52
https://www.youtube.com/watch?v=Y37okQAN7uA
Jun 16, 2010 - Uploaded by WatchDudeMark
In this video I will show u how to size your watch band with around the ... didn't need to watch it as you're obviously too fxcking useless to do ...
How do I open the band? - Fixya
www.fixya.com/support/t26047908-open_band
33 mins ago - Generic Ladies TFX Stainless Steel Watch W/ Rectangle Face ...watch? The clasp won't open and I didn't want to pay $65 just for a new clasp.
Jan 10, 2016 | Generic Ladies TFX Stainless Steel Watch...
Need to replace or repair a Bulova watch band C877668. One of the links broke. Stainless steel backing
I took mine to a watch repair shop but make sure your watch is worth repairing as it's not cheap.
Dec 31, 2015 | Bulova Watches
Extra links 96r000
You can go to any jeweler that handles Bulova watches and talk to them. I don't know if they will have the extra links but they might depending on how popular the watch is. They would also be able to show you other bands that can work for you and that watch.
May 16, 2015 | Bulova Watches
I NEED TO KNOW YEAR OF BULOVA LADIES WRIST WATCH ITS 10 KT AND I HAVE A SERIAL NUMBER z78782. it has bulova ms on back
A Bulova "M5" code would indicate that the watch was made in 1965. Vintage Bulova watches can be dated by this little alphanumeric code:
Lx = 195x Mx = 196x Nx = 197x Px = 198x Tx = 199x
Pre-1950 Bulova watches used a variety of symbols and numbers (e.g., 47 and 48 to designate 1947 and 1948) to show the model year of the watch. A chart of those symbols can be found here: http://www.manleyhorlogerie.com/Watch_History/bulova.htm#Bulova%20Date%20Codes
Jul 13, 2011 | Bulova Watches
I received a new Bulova Marine Star Men's watch but lost the manual. I need to download a manual. My model is goldtone adjustable band with black coated center line. Besides the clock it has 3 other...
If you go to the Boluva web site http://www.bulova.com/brands/bulova/bulova.aspx?brand=bulova#coll_id=30&coll_name=Marine Star&gender=1 you will be able to find your watch on their list.
Click on your model and you will see a page with information on the watch which includes operating instructions which you can download.
Dec 08, 2010 | Watches
Link removal from band
if you don't have the necessary tools or knowledge then your best bet is to take it in and have a professional remove the link(s) for you. It all depends but sometimes if you take it to Macy's or Neiman's they will do it for free.
May 23, 2009 | Bulova Watch
I need to add 2 links to a ladies bulova watch model 98r98.
Aug 09, 2008 | Bulova Watches
Users manuel
The following provides access to a two page operating instructions document this document is titled "Watch Setting Guide".
To access the document you will need Adobe Reader (free)
If needed click the Get Adobe Reader button on the following link
http://www.adobe.com
Watch operating instructions
http://www.bulova.com/dynamic_repository/instructions/593W.pdf
There are some additional manuals that might satisify your needs here too (you probably want Wittnauer at the bottom of the page - includes the one above)
http://www.bulova.com/service/instructions.aspx
Jan 01, 2008 | Watches
Watches Logo
131 people viewed this question
Top Bulova Watches Experts
Arturs Kalnins
Arturs Kalnins
Janelle Schoonover
Janelle Schoonover
Are you a Bulova Watch Expert? Answer questions, earn points and help others
