Question about Vtech Toys
Vtech InnoTab rechargeable battery pack not charging
    Top Expert:
  • Vtech Master
  • 52,781 Answers
  • Defective battery
  • Defective charger
Posted on Feb 22, 2017
SOURCE:
emissionwiz
  • 85108 Answers
SOURCE: 21.6 VOLT RECHARGEABLE POWER PACK WON'T HOLD A CHARGE
There is nothing to do but replace it, they do wear out.
Posted on Nov 07, 2008
  • 25 Answers
SOURCE: wii fit board rechargable battery pack
This is really very frustrating when you face such kind of problems. You may check out Wii Fix Guide to fix the problem yourself. This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Posted on Feb 20, 2009
eradiostore
  • 1655 Answers
SOURCE: How to charge battery in Motorola Talkabout Distance DPS
You can obtain a wall adapter style charger for your radio at your local Motorola dealer, or online at http://www.eradiostore.com/cart/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&epcode=Y&q=htn8232
Sidenote: The rechargeable battery is good for about 2 to 3 years. You can tell the age of your battery by looking at the date code on the back of the battery above the stop sign. The first number is the year, the next two numbers are the week of the year. 915 would be 2009 the 15th week. (Or if very old it could be 1999 the 15th week.) A good battery, when charged will go an 8-10 hour day.
Keep both of your charge trays, replacements for these are no longer available.
Posted on Apr 12, 2009
  • 699 Answers
SOURCE: Logitech MX1000 Laser Cordless Mouse, I replaced
Li-Ion battery and NiMh battery have completely different charging requirements! Li-Ion battery has much stricter charging requirement and the regulator is normally design to trickle charge at 0.1 Current rating @ 4.2V and then completely shut down.
WARNING: if you use a Ni-Mh charger on a Li-Ion battery, then it will erupt and even explode and catch fire!
Bottom line is that the rescued Li-ion regulator is not designed for your Ni-Mh pack and you will never get a full charge with it and you will need a completely different regulator board: you are better off putting in a suitably sized Li-Ion battery with inbuilt regulator but with higher current rating if possible.
Hope it helps! Let me know how you go.
Posted on Jan 05, 2010
soupyspoon
SOURCE: vtech innotab wont turn on
I had this problem. There are two sets of batteries--the AA's and a button battery. The button battery is behind a compartment with a tiny screw. I took out the button battery (which took some work because it was in there pretty tight) and the AA's at the same time. When I put them back in, everything worked
Posted on Jan 11, 2012
My sons innotab 3s won't charge
try usiing just the charger without the rechargeable batts...if toy turns on with just that then prob maybe eiither the toy itself or you need new rechargeable batts
Feb 15, 2015 | Vtech InnoTab 3S The Wi-Fi Learning App...
Why does innotab charging light blink when charging and will not charge?
the charge imdicator is suppose to blink when you plug the toy to the wall adaptor. if it doesnt blink then there's something wrong with either the adaptor, the adaptor port on the toy or the rechargeable power packs. now i said that the light is suppose to blink. but the frequency of the blinks shouldnt be fast. if that's the case clean the compartments and re-insert the batteries. if you are still having problems try the ff T/S:
1)remove the power packs, plug the toy to adaptor and turn it on. if it turns on that means your adaptor is working.
2)remove the adaptor and try using just the power packs.
3)try using 4aa batteries.
if the toy turns on with only one of the power sources stated above you better call vtech hotline.
Sep 01, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
My daughters pink vtech innotab 3s touch screen seems to be not working, she cant touch anything
Try recharging the batteries, or try using another powersource. if this does not resolve the issue then you may need to call their hotline
Mar 19, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
Touch screens not working
Have you tried Screen Calibration? If you are using new batteries and you have tried calibrating the screen, but still not working, then you need to call VTech Hotline at 1-800-521-2010
Jan 10, 2014 | VTech Communications INNOTAB 2 PINK
Trying to connect the innotab 3s and it says the security mode being used by this network is no longer in standard mode
please read the review below as I think you may need to download patches and firmware updates to maybe fix your problems.
http://au.pcmag.com/vtech-innotab-3s/383/review/vtech-innotab-3s
Dec 08, 2013 | Toys
Screen not coming on vtec innotab 2
try replacing the batts. if that doesn't work, call vtech
Dec 01, 2013 | VTech Communications INNOTAB 2 PINK
Innotab 2s can't connect to computer via USB.
try another USB cable/usb port. if that doesn't work: For windows--check under device manager>>disk drives>>look for vtech nand1>>right click--uninstall>>unplug the toy>>plug it back in>>turn it on>>try to access Learning Lodge again. For Mac>>open Disk Utility while toy isnot connected to toy.>>plug toy to computer>>turn it on>>look for anything that says vtech.if you do go to Learning Lodge--send error report--call vtech
Mar 29, 2013 | Vtech InnoTab 2S Wi-Fi Learning App Tablet...
Pocket Vsmile
Maybe you have to buy a new rechargable battery pack. I have had one before and for some reason it no longer charged well. It too would hold a charge for only a small period of time, definately not long enough to appease my daughter! :) Try giving vtech a call and see what they say. At the very least they can help you get a new pack. Here's the number! 1.800.521.2010 :)
Aug 24, 2008 | Vtech V.Smile Pocket
Toys Logo
210 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
ibanez1403
Level 1 Expert
Keith Koene
Are you a Vtech Toy Expert? Answer questions, earn points and help others
