SOURCE: A red light all the time on xerox phaser 6110.
I think I might know what this is. Mine did the same and I removed the waste toner cartridge (grey L shapped unit to the right of the colour cartridges under the front panel) I noticed it was quite full but a rocked it from side to side to settle the contents (be carefull as they can come out) and when refitted the light stayed off when powered up. I'm not sure if this waste cartridge needs to be replaced or you can simply tip it out into a bin, but I'll try that tomorrow when I can empty out side.
SOURCE: xerox phaser 6120 laser printer paper jam fuser
Fix, well i am a dentist in Marysville washington and just got this printer from a family member and same thing was going on.
I looks like paper stuck in the middle roller. I just got a small mirror and pair of dental tweezers and removed a lot of jammed paper. it works fine now but you need do go to the dental section in drug store, so you can see where the jam is at.
SOURCE: how can you reset the waste toner counter?
Exactly the same problem over here ;-( When replacing the toner recently i forgot to switch of the power, so no reset. I can't find the reset option in the menu, resetting aal settings did not solve my problem.
SOURCE: Mac OS 10.6 Snow Leopard: Printer
1) Change the “Xerox” Folder Permissions:
• Navigate to Applications > Utilities and open a Terminal window.
• Type the following command: sudo chown -R root:admin /Library/Printers/Xerox
• You will be prompted to enter your password.
2) Install Rosetta from the Snow Leopard DVD:
• Insert the Snow Leopard Install DVD
• Select Optional Package
• Select “Rosetta only” from the list of optional packages
• Click install and follow instructions to complete installation; there is no need to reboot
3) Reset Printing System:
• Navigate to: System Preferences> Print & Fax> Xerox Phaser [6100, 6110, 6110MFP]
• Right click on the printer
• Select Reset Printing System
4) Install Printer (without removing the driver):
• Select +: add the available Xerox printer
