It said change your password on Microsoft account...I did, but still cannot open my laptop...!!
The easiest and most efficient method is using Windows 7 password recovery reset disk. iSeepassword Windows Password Recovery Pro allows you to create an all-new password restore disc to find Windows 7 password.
The article below tells you how to crack forgotten password in Windows 7 specifically.
https://www.iseepassword.com/forgot-my-acer-laptop-password.html
SOURCE: acer aspire 3003lci forgotten bios password
you will need to disconnect the cmos battery for a few seconds to allow the bios settings to revert to default, reconnecting the cmos battery will allow you to boot up without a password, howver any changes which were made to bios settings will be lost....have you tried pressing f8 while booting, then selecting the option "last known good configuration" ?
SOURCE: Not working right click of touch pad of Acer Aspire 4710z
Hey!
What operating system are you running? All I could find was a manual for your model: http://tinyurl.com/6gc7pl
If you are using Windows XP, you might try going to Control Panel -> Mouse -> On the first tab (Buttons) check "Switch primary and secondary buttons." then hit "Apply".
Try left-clicking (currently assigned to be the right-click) on your Start button and see if the menu with "Explore All Users" on the very bottom opens. If it does, then your touchpad is most likely defective and would have to be fixed (www.fixmyacer.com). If the menu doesn't come up, then it is a software issue and is 100% fixable.
Matt Newelski
www.newelski.com
SOURCE: forgot windows password
Hi, why don't you remove the password with Windows Password Recovery 6.0? If you can’t remember the windows admin password, try to reset it with a reset disk. Free download windows password Recovery from http://www.recoverlostpassword.com/products/windowspasswordrecoery.html and there is a .iso file included. Burn the .ISO file onto a blank CD which is called windows password Recovery disk. With this disk, you can reset the unknown password without erasing anything
SOURCE: How to unlock hdd password on a acer laptop it's a acer aspire 7731z-5731
This work on some Acers you should give a try!... I BOOT THE LAPTOP WITH AN UNLOCKED HDD ENTER TO THE BIOS PUT A PASSWORD YOU CAN REMEMBER SAVE AND REBOOT THEN ENTER BIOS AGAIN AND ENTER THE OPTION TO CHANGE THE PASSWORD THIS TIME ENTER YOUR SAVED PASSWORD THEN LEAVE IT IN BLANK ONE TIME AND BEFORE COMFIRM SWAP THE HDD PUT THE LOCKED ONE IN THE BAY AND COMFIRM A BLANK PASSWORD AND VOALA!!! UNLOCKED.
