Question about Sharp Microwave Ovens
MODEL R-395Y sharp carousel microwave not working. All power outlets are fine. Please help, cheers lyn
  • 794 Answers
I was unable to locate a service repair manual specific to your microwave; sorry.
You'll must likely have to find a Sharp service and repair center.
I've attached a link that contains the user's manual to your microwave...it has the phone number and address of Sharp; perhaps you can phone them and ask where a repair center is located.
This is the diagnostic check list Sharp recommends before calling for service:
SERVICE CALL CHECK
Please check the following before calling for service:
1. Does the display light up?
2. When the door is opened, does the oven lamp come on?
3. Place one cup of water (approx. 250 ml) in a glass measure in the oven and close the door securely. Oven
lamp should go off if door is closed properly. Press the INSTANT COOK/START pad once.
A. Does the oven lamp come on?
B. Does the cooling fan work?
(Put your hand over the rear ventilation openings.)
C. Does the turntable rotate?
(The turntable can rotate clockwise or counterclockwise. This is quite normal.)
D. After one minute, did an audible signal sound and COOK
indicator go off?
E. Is the water inside the oven hot?
If "NO" is the answer to any of the above questions, please check your wall socket and the fuse in your meter box.
If both the wall socket and the fuse are functioning properly, CONTACT YOUR NEAREST SERVICE CENTRE
APPROVED BY SHARP.
Sharp Carousel 395Y Operation Manual And Cookbook
Posted on Feb 22, 2017
SOURCE:
Sharp Carousel Microwave Mdl 1875 for our RV is dead
>> We also tried plugging our toaster into the microwave plug outlet, and the toaster wouldn't work in that outlet, but worked just fine in a different outlet in the RV.
This means the outlet you plug your microwave into needs to be fixed in addition to fixing the oven. Breaker? Fuse?
>> I understand from another RV forum that microwave ovens for RVs have "special circuitry and cooling features" not found in regular countertop ovens for household use.
Not really in my experience. Any microwave supplied with clean AC power and proper venting space will be fine.
But I'd bet your microwave can be fixed affordably.
The main internal things which can result in this model being dead (no display, no light when you open the door, no beep when you press a pad on the keypad) would be the 20A fuse and the magnetron temperature fuse. There could also be bad connections on the noise filter board.
Also, sometimes a power surge can cause the power to be interrupted to the low voltage transformer on the board, and I regularly repair those boards. I can also write a technical statement to your insurance company or to an RV park as needed.
At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The relevant service manuals for this model are here and here.
You can order Sharp parts from Sears or Encompass.
Contact me directly if you need more help.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Mar 08, 2017 | Sharp R1875: Over the Range Convection...
I have a sharp carousel over the range microwave oven R-1505LK no power the outlet is ok did lose power to the house and the microwave didnt come back on where is the fuse located
The fuse is usually located inside the cover near where the power cord enters...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 16, 2010 | Sharp R-1505 Microwave Oven
Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
Sharp Carousel Model R-1874 no heating or turning, display works
sorry without seeing the machine we can not help try whatever you want . that is how many of us learned what we know today
Nov 17, 2017 | Sharp R-1874 Convection/Microwave Oven
Roller Stay for Sharp Carousel microwave oven
u can try www.partstore.com
but the tray roller is pretty much univeraql if you have problems finding it for that model alost any sharp tray roller will fit the unti
i just grabbed one out of the dump for my personal un it and it works fine
Oct 09, 2009 | Sharp KB6024MK 1000 Watts Microwave Oven
Sharp Carousel Microwave has no power
I too believe that a "protection fuse" was possibly blown. It would need to be found and get replaced. Hopefully it is just a fuse and nothing else because the way it sounds to me, the microwave may be damaged.
Good Luck!
Jun 11, 2009 | Sharp R-1870 Convection/Microwave Oven
Sharp Carousel Microwave R-1460A no power, door switch went first
You will want to replace the fuse and door switches. You will not be able to run it without replacing door switches. You do not need a new microwave. Door switches go bad, it has nothing to do with radiation.
Feb 19, 2009 | Sharp R-1460 Microwave Oven
Sharp Carousel R-395F(S)
We repair those for US and Canadian customers for $39.95, but in the UK you can contact Quality Electronic Repairs. I think they repair these.
If you want us to do the work for you, you'll need to add $15 for extra shipping and as much as $39.95 for other countries.
Feel free to contact me directly (and please remind me of your full model number) for more information & help or see our Web site.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Feb 02, 2009 | Microwave Ovens
Microwave Ovens Logo
136 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
