SOURCE: fossil blue collection wrist watch, services in hyderabad and cost
You are now way NEAR a center. You will have to go to Fossil.com and find one in a nearby country.
SOURCE: Brand new watch won't work
Check your users manual if your watch have two batteries. If yes, you need to replace digital part battery.
If your watch has only one battery, your digital screen or plate is defective. Bring it back to the retailer and ask to replace for the decently working watch.
But first of all try to fiddle with all pushbattons- sometimes it helps.
SOURCE: remove links from fossil metal band
You may have
arrows inside bracelet.Arrows are pointing the way the pins must come
out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws.
If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx.
size of pin end diameter using any sharpening stone or sandpaper. Get
an old towel and fold it to make a soft base for work (like small
cusion). As you don't have a special bracelet holder you will need a
pair of helping hands to hold the bracelet steady upright. You will
need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make
sure that the grooved pin ends are facing towel, not the needle and
hammer!!!
Now place the watch on the folded towel, take that needle and smallest
hammer you have and start driving the pin out using light blows. Do Not
hit hard, as you will brake the needle, scratch your watch or even
injure yourself. Watchmakers are using 45 gram hammer, so, calculate
your strength of blows.
After a few blows check if the split end is coming out and when you see
that the end is long enough to grab it with pliers, pull the pin out
with pliers. When pulling, do NOT turn pliers, as pins tend to brake
when twisted. Use firm grip and your strength to pull the pin without
twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY
the same way as they came out- the blunt end first in the hole and the
split (grooved) end last. Before doing that check remaining pins in
bracelet to make sure that you put them back from the right side of
bracelet.
It is recommended to use plastic hammer to drive pins back in or you
will scratch or damage bracelet. If plastic hammer is not available use
an old toothbrush handle (or some plastic item) as an absorber. Simply
put pin into the hole as deep as you can with your fingers, put the
toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
SOURCE: How to change my battery on my fossil watch?
when you look at the back are there three small rectangular indents
evenly spaced on the edge on the back? If so you'll need a special tool
for opening waterproof watches. the tool adjusts to fit the three
indents then press down as you turn counterclockwise. you can find the
tool on amazon.com or your local jewelry store. make sure the gasket is
in place and not damaged before screwing the back on.
here is a link to the tool
http://www.amazon.com/Pavilion-Professional-Waterproof-Adjustments-Caseback/dp/B000K3SK0Y
the type f battery will be written on the battery and you can usually find them at a drug store, hardware store or jewelry store that sells watches.
