SOURCE: I can't change the channels on the tv with remote or on tv contro
You will need to rescan for channals, or manually enter the number. Make sure your sat. box is on when you do this. Rescan can be found in your tv.s menu.
SOURCE: dish network remote stopped working for on and off and volume
First before trying to repair the remote lets try to just reprogram it. The easiest way to do this is to do a search. 1st Turn the tv on, then on the remote press and hold the tv button until it flashes. Next press the tv power button. Next press the up arrow button slowly until the tv turns off. Then hit the # key. Now if you pressed the up arrow to many times and the tv doesn't respond to the remote just start the process over, except using the up arrow use the down. You may have to push the up arrow button many times before it finds the code. The batteries usually last quite a while since there are 4 of them. If this doesn't work call 1-800-333-dish they will either send out a tech or just mail you a new one. If you have the user guide for the 722 the instructions to do this are on page 82.
SOURCE: SNOWY screen--can't find the right channel for Dish Network
Press INPUT button on your TV remote and select right input.
SOURCE: I cant get my Sony tv to change to channel 60 or
It is probably a problem with your original setup if it has a built in digital TV tuner then you may have accidentally done a scan for channels. If you did not have an antenna attached to your TV then it would have come up with no results but would only let you go to one channel (whichever one you started on).
SOURCE: Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
