Vacuums Logo
Dana Beck Posted on Feb 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My belt came off my Riccar Radiance when I took the brush out to clean the hair off, how do I get the belt back on
Thatvacguy.com
Level 3:
  • Riccar Master 1,619 Answers
  • Posted on Feb 23, 2017
Thatvacguy.com
Riccar Master
Level 3:
Answers
1619
Questions
0
Helped
604664
Points
3345
The belt has to go around the motor shaft then under the roller on the pivoting lever (it's called the hall sensor) then around the brush roll. It may be easier to remove the top cover of the nozzle housing by removing the 5 screws from the bottom of the vacuum.
5 Related Answers
Anonymous
  • 1673 Answers
  • Posted on Mar 20, 2008
SOURCE: vacume brush won't turn but belt is not broken
The belt is probably stretched and won't drive the brush roll. Also check the brush roll, the ends should turn freely, if no, then replace it also.
dave taylor
  • 78 Answers
  • Posted on Oct 29, 2009
SOURCE: how to refit the front brush belt driven roller
hi well if you go onto youtube and look for replace dyson clutch it will show you how to refit your brush good luck
Anonymous
  • 701 Answers
  • Posted on Dec 15, 2009
SOURCE: Riccar 8800 belt replaced but now floor brush won't spin
Are you sure that you get the right sized belt? This is the correct one you need:
Riccar 8800 Belt
Anonymous
  • 52 Answers
  • Posted on May 21, 2010
SOURCE: riccar model rad.7 upright (radiance). roller
As you already know, the red brush indicator light indicates that the brush roll has stopped turning, usually because an object has become stuck in the brush roll. When that happens you should turn the machine off (unplug it also for safety), remove the obstruction and turn the vac back on. That should have cleared the light and allowed your brush to turn again.
Occasionally, you will get debris in the brush roll end caps and the brush roll will spin slower making the sensor think there is an obstruction. You can remove the brush roll, pop the end caps off and clean out any debris to see if that helps.
If none of the above worked it is possible that the brush roll sensor is bad or the circuit board in the machine is bad. You'll need a Riccar service center for that. The good news is your Radiance has a 6 year warranty.
askdyson
AskDyson
  • 2572 Answers
  • Posted on Sep 05, 2011
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: My Dyson DC14 Animal brush
    I'm sorry to hear you're having difficulties with your DC14. If you haven't already got in contact with us directly, I'd encourage you to do so. One of our experts will be happy to run through some troubleshooting over the phone with you to identify the cause of the issue you're experiencing, and will be able to recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Dyson Online Customer Support
    How do i install a vacuum belt?
    It should loop around the roller, Rachelle, then twist one-quarter turn to hook over the motor shaft (the steel one that points straight down). Now, it CAN be hooked over the motor shaft in either of two directions, depending upon which direction you twist it - one way will make the roller run backwards and probably pop the belt back off the shaft. The other way is the correct way - if the roller rotates the correct direction when you bump the power switch, then it's on correctly.
    Where is riccar radiance filter reset button
    Remove the bag door, you will see a little round rubber piece about 1/4 in diameter on the motor cover. Remove the rubber piece and very gently push the button while the brush roll motor is running
    1helpful
    Accessing the motor on a riccar radiance
    On a Radiance you will need to remove the screws going through the bottom of the vacuum nozzle housing which hold the cover on. Remove the cover and remove the screws holding the cover that goes from the brush roll to the lower motor. When you remove this cover tpyou will be able to see into the fan of the lower direct air motor to remove the obstruction. If it is in too far. You may have to pull the motorand open up the fan. This is not a hard thing to do but. If you have never done it, it can be a confusing job that may be best left to your Riccar dealer.
    Radiance RAD.4 Vacuum squeals when powering on or running the brush
    It might be a bad bearing in the brush roll or the hall sensor is squealing. I recommend taking it to your local dealer to have it checked. Failure to fix it properly could cost more in the long run.
    I need to replace the belt on my Riccar supralite vacuum and need instructions
    Lay the vacuum upside down, remove the bottom plate, remove the brush roll and belt, install new belt around motor shaft and brush roll, pull on brush roll to stretch belt far enough to drop brush roll back into place.
    Broken handle riccar radiance
    Take the broken part to your Riccar dealer. The newer models have an upgraded more durable handle. You can get the upgrade for an older model.
    Hello, I have a Riccar 8000. The belt works, the bar spins, and it will **** things up. However, it will not pick up threads and dog hair or anything from the carpeting. Mu husband took the bottom off and...
    The belt should be replaced at least once per year. They lose elasticity and will slip when vacuuming. The brush strips in the brush roll can be replaced. It is well worth having it serviced by a Riccar dealer,. The 8000 series can last many years but any long lasting vacuum will require routine maintenance.
    2answers
    Won't pick up dirt and hard to push
    This sounds like it is most likely a belt issue with your Riccar. In order to verify this, turn the vacuum on and turn it over on it's side after making sure that the carpet / floor switch on the top of the roller brush housing is turned to Carpets.
    When you turn the vacuum on after changing the switch to carpet mode, does the roller brush spin? The belt controls the the roller brush and makes it spin. When the belt is broken or stretched out, and the brush is not spinning, or stops as soon once it hit carpeting, the brush roller will no longer help pull the vacuum forward. This would explain why the vacuum is very hard to push.
    In order to help you the best, I went ahead and took some pictures for you on how to change the belt. The only really tricky part is the clutch actuator arm. If you don't already have a new belt, here's a link for you to a 2 pack of belts for your 8955 on our website:
    Riccar 4000 / 8000 Series Upright Belts (2pk)
    The model that I took pictures of is actually a model 8650, but this is identical in every way to your 8955 in terms of changing the belt.
    What you'll need to have handy for this repair;
    - Phillips Head Screw Driver
    - Riccar 4000 / 8000 Series Belt
    - Riccar 8000 Series Roller Brush With Clutch Assembly (only if the brushes have worn down, not necessary if brushes are still long)
    Step 1: Make sure the vacuum2_bing.gif cleaner is unplugged, and turn the vacuum cleaner upside down so the bottom plate is upwards. It's easiest to do on a work bench or counter top.
    Step 2: Unscrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush.
    Step 3: Remove the belt guard that sits to the left of the roller brush, this is a metal part that protects any dirt & debris from going over to the belt. Here's a picture of that part being removed;
    Step 4: Remove the Rug / Floor actuator arm from the clutch on the right hand side of the roller brush. Simply pull the metal actuator arm to the left of the brush and out of the circle that it sits in. Here's a picture of that;
    Step 5: Once you have removed the actuator arm from the clutch, as well as the belt guard, lift straight up on the roller brush and remove the roller brush from the vacuum cleaner:
    Step 6: Once you have removed the roller brush, and the old belt from the vacuum cleaner, take a new belt and wrap it around the metal pin in the back of the vacuums agitator housing. Here's a picture of where that pin is located with the belt wrapped around it;
    Step 7: Once you have the belt wrapped around the metal pin (this is the shaft to the motor that actually spins the belt), put the other end of the belt through your roller brush;
    Step 8: There is a specific way that the roller brush has to be inserted. If the roller brush is not put in properly, this can cause all sorts of problems including the brush not spinning, as well as continuously having to replace belts. You can see on the end cap of the roller brush (the right side where the belt rides) that there are two little teeth that protrude out of the end cap. Here's a picture of how it looks:
    Step 9: With the roller brush inserted through the belt, position the two teeth facing downwards. You can see in the vacuum cleaner where the roller brush sits, a little groove inside of the roller brush housing. These two teeth need to straddle that groove. Also make sure that the little ring, or circle that the clutch actuator arm sits into, is facing upwards completely. It should be directly on top of the two teeth. Stretch the belt using the roller brush as leverage down into the agitator housing of the vacuum cleaner, making sure that the two teeth are facing downwards straddling the little groove. After the brush is back into the vacuum cleaner, take the metal actuator arm from the rug / floor switch, and insert it back into the metal ring (or hole) on the roller brush;
    Step 10: Replace the metal belt guard that rests to the left of the belt. You'll notice on the belt guard that there are two little 90 degree notches on both sides. These notches need to face towards the belt or to the right.
    Step 11: After inserting the belt guard back into the vacuum, turn the vacuum cleaner over so the top of the agitator housing is facing you. Make sure that the rug / floor switch set to the carpet setting again, and then turn the vacuum upside down again so the brush and belt are exposed again.
    Step 12: With the vacuum set to the carpet setting, pull the belt forwards to ensure that the brush is spinning freely. If the belts do not spin freely, repeat steps 2-10.
    tep 13: The last tricky part can be reinstalling the metal bottom plate. There is a little lip on the front of the vacuum cleaner that the edge of the bottom plate has to slide under for it to be installed properly. A lot of people just install the bottom plate over top of this lip, and this prevents the brushes from hitting the carpet as close as if the bottom plate is correctly installed. It will take away the vacuums cleaning cleaning ability dramatically. Here's a picture of the lip with the bottom plate in the backgroud;
    Step 14: Slide the metal bottom plate into the lip on the vacuum cleaner, and fasten the screws back into the bottom plate to secure it. This is the way it will look if the bottom plate is installed the WRONG way.
    Here's a picture of the RIGHT way to install the bottom plate:
    The Riccar 8955 is great vacuum, and cleans better then most other upright s when it has a new belt on. I hope that this repair solution is helpful to you in fixing your vacuum. If you did, please be sure to click the Thumbs Up Icons in the top right hand corner of the solution. Feel free to request a clarification on the repair if you have any questions. I'm always happy to answer any questions. I hope will consider GoVacuum.com storefront for any Riccar supplies that you may need. We carry all Riccar Vacuum Bags, Filters, Belts, and Parts.
    Thank you very much,
    Chris J.
    GoVacuum
    1helpful
    2answers
    Riccar model rad.7 upright (radiance). roller brush won't turn and red roller brush indicator is on. roller will turn easily by hand and belt is in place. how do i fix this?
    Top Riccar Vacuums Experts
    ADMIN Andrew
    ADMIN Andrew
     Mikey
    Mikey
    Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
