Question about Leisure Kitchen Ranges
The clock on my Leisure LEVC66 cooker has has come away from its fixings and gone inside the cooker.Is there a way of taking the top off to fix this.
SOURCE:
  • 3 Answers
SOURCE: can you help me find a user guide for leisure
I could copy my handbook of the Users Guide for a Rangemaster 110 Gas appliance if you wish and send it on to you, if that would help.
Posted on Oct 23, 2009
kingbrizzle
  • 407 Answers
SOURCE: The clock is still visible, but there is moisture
It can be fixed, but you will have to basically take it all apart to do it, which can be a pain in some coffee makers. Then again, some are fairly easy. Second, yes, it will eventually go away, unless it is just getting caused by the coffee maker coming on. It shouldn't hurt anything, but can still be an annoyance. Hope this helps.
Posted on Dec 31, 2009
barkencoa
  • 3463 Answers
SOURCE: Cooker clock requires resetting
You need to press 2 or more of the timer/clock buttons in seqeunce to cancel the auto setting.
The sequence of buttons varies according to the make of cooker, so just keep pressing the buttons until you hit the correct sequence.
Hope this helps.
Posted on Jan 07, 2010
  • 149 Answers
SOURCE: I have a leisure rangemaster 110 dual fuel cooker.
at the back of the timer/clock there are 4 wires live and neutral to power the timer/clock and 2 others they may be red or orange. safely connect these other 2 together and you are good to go. if you need a new clock email me info@topoftherangeltd.co.uk
Posted on Mar 27, 2010
  • 1739 Answers
SOURCE: my rice cooker doesn't work...
The manual for your Zojirushi NP-HBC18 Rice Cooker can be found here:
http://www.zojirushi.com/servicesupport/manuals/manual_pdf/nphbc.pdf
Refer to page 12 of the pdf for Troubleshooting and page 13 for Error Displays
It may be that the stored Lithium Battery requires replacement.
Suggest you contact their Customer Service for information on the battery and how to replace and whether there are Service centers in Australia:
http://www.zojirushi.com/support/customer_service.html
Posted on Mar 15, 2011
The glass lid on my leisure cookmaster 101 FRKP won't stay up. How can I fix it?
sadly I can find nothing about a glass lidded cooker of that MAKE model
Oct 28, 2017 | Leisure Kitchen Ranges
Rangemaster 55 leisure. My timer has stopped working
Hi Stella,
i am sorry for you, but you can forget repairing the timer.
You can replace it of course.
You do not need the timer to operate the oven.
For that you need to bypass the timer. The clock will stay working normally.
Although the 55 is smaller then the 110, the working of the clock should be the same.
Net link will give you more information and I hope you will fin the solution there.
Kind regards and a good weekend, Dik
Leisure Rangemaster 110 Electric Range Cooker How to bypass
Feb 28, 2017 | Rangemaster LEISURE 55 & 110 FAN OVEN...
My gourmet classic leisure cooker has a noisy fan. What can I do?
Hello CAROL ROSA,
If it is NEW... TAKE IT BACK.
ELSE... (replace the fan).
Post the actual model number to see if
we need to look for 'parts' (USA) or "spares" (rest of the world)...
Together we can get this
'FIXED' (USA) or "sorted" (rest of the world)...
http://www.harveynorman.ie/home-appliances/cooking-appliances/range-cookers/leisure-gourmet-classic-oven-grb6cvr.html
Aug 30, 2016 | Kitchen Appliances - Others
Leisure levc66
check the fan itself..if it wont run.. replace it..
Jan 03, 2014 | Pool & Spa
Have a Leisure roma 100 cooker model number RM10FRS main fan oven not heating need a service manual to find out how to get at heating element to see if needs replacing.
most likely thermal fuse behind oven take off back plate and you will see the brown wire with the heat shrink sleeving covering the fuse.wire and fuse comes as one part
Jul 05, 2010 | Kitchen Ranges
Just bought a Leisure Gourmet Classic gas cooker. Connected the gas and plugged it in but none of the burners will light. The ignition is working but no gas is getting through. Any ideas folks? TIA, Andy
I had a similar problem when my new Leisure cooker was installed last December. The burners would light when I held the knobs in but when I let go the flame would go out. The engineer took off each of the burner knobs and stuck a small wad of aluminium foil between the inside of the knob and the contact on the front of the cooker - he said it's a design fault and the gap is just a bit too large for contact to be made reliably. This fixed the problem and I've had no trouble since.
Jun 22, 2010 | Ovens
I have a leisure rangemaster 110 dual fuel cooker. The auto timer has gone wrong. How can I bypass this timer
Feb 12, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Kitchen Ranges Logo
46 people viewed this question
Top Leisure Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
Chuck Graybill
ray gallant
ray gallant
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
