SOURCE: Need Free down load of repair manual
Might be a little different then what you have as the manual varies by serial number but try this:
http://www.hondapowerequipment.com/pdf/manuals/31VH7H20.pdf
SOURCE: I have a honda xrx 217 mower. the left rear height
Just spray it where it adjusts with WD-40 or better rust remover. Get good stuff at your Auto Supply Store. Let it work overnight and your problem should be solved.
SOURCE: Honda lawn mower bent crankshaft repair
I would start by making sure the crankshaft is actually bent, as a pro I've owned Honda mowers and throught he years I've hit all kinds of things and have never bent the crankshaft of any mower, these were regular mowers not some super commercial model so get a second oppinion, if the crank is bent buy another mower as it's too expensive to fix and you will lose warranty anyway and then get rid of that stump!
SOURCE: I am having to replace
Your answer can be found at the link below on page 44. This will walk you through removing the cable and the settings for adjustment after replacement
http://www.hondapowerequipment.com/pdf/manuals/31VH7001.pdf
SOURCE: Honda mower engine oscillates when idling. Check it out: http://www.youtube.com/watch?v=HbmtcyPR2DM
The carb needs to be cleaned. The main jet and nozzle are the areas to pay attention to. The main jet screws into the carb in the same spot that the float bowl screw goes into. The nozzle sits above that and if you tap the carb (carefully) on the bottom once the main jet is removed the nozzle will drop out. Use a small piece of wire to clean all the small holes in the jet and nozzle. Make sure they are open and free of clogs. This is a common problem with all small engines.
