Running Win 7.
SOURCE: Epson Printer Setup & Support Number Call 1-8O5-225-669O We are 24 Hour Available Call Now.
I had the same problem with an Epson R340 printer and Epson Print CD software after installing Leopard. Here's what I did. Go to System Preferences. Select Print & Fax. Select the "+" box on the lower left part of the screen. Select Epson Printer -- USB and click "Add" and "continue" in the box that comes up (if it does). Now see if Epson Print CD will print to a CD. If it does, great. You can now actually go back to System Preferences and Print & Fax and delete the printer you just added by clicking on the "-" box and Epson Print CD will still work. Now I found another problem with printing. The CD printing is now off center to the right and down, so in Epson Print CD program you have to click on print and from the print screen click on "Position Adjustment" in the bottom left corner. I've found the perfect position is 3.5 mm up and 3.5 mm left to make everything print perfectly. Good luck.
SOURCE: Epson RX500 printing problems
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
SOURCE: Mac OS 10.5 Leopard
First, install "epson easyprint" from the epson website. Its found under drivers and support for your unit.
Then click ok on that error message about "driver dealing with..."
After
you click ok on the message, you will get another window where you will
find a "manual print" button. Click on this manual print button and
this will take you to the next window where you have to select "A4 as
the paper size" and "CD/DVD as the paper type and paper path" . After
this, click print... it should start to print! This is just a
workaround until epson gets a patch for leopard for print
cd........hopefully
SOURCE: Epson Stylus Photo RX500. I was cleaning print
Press all these buttons:
Power+Load/Eject+Stop+B&W+Color
When printer turns ON, "Init eeprom" appears
Release and Press the Color button.
SOURCE: Epson Stylus PHOTO RX500 - PRINTER ERROR message
keep pressing the button, until it stops where you want.
good luck
