Samsung YP-U2X Digital Media Player Logo
Posted on Nov 20, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
YP-U2J Samsung mp3
I tried charging my mp3 device from a work computer and once I placed it into the USB port the device locked. I doesn't seem to reset or stay powered up--just shows padlock icon then disconnects again, did I ruin the device? Or is there a solution?
  • Anonymous Feb 19, 2008
    I have the same problem. I made sure the key isn't locked. But it still shows the padlock icon on screen. I also tried to use the 'reset', but it doesn't work...Any idea?
Tyler Harris
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 02, 2015
Tyler Harris
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1659
Points
My hold switch was broken. It slid too easily back and forth; you should be able to feel it doing something.
To fix: remove the two screws at the USB end; carefully pry the front face up until you can remove the hold slider. Either fix the back of the broken slider OR do what I did: manually move the internal switch out of the hold position and break off the other side of the slider (I can't use hold anymore; but, I don't have to worry about it breaking in the hold position again).
Anonymous
Level 2:
  • Expert 52 Answers
  • Posted on Dec 02, 2007
Anonymous
Expert
Level 2:
Answers
52
Questions
0
Helped
23569
Points
111
Actually u've only activated the hold key. just push the key in the opposite direction to unlock it. The hold key on the side adjacent to volume '-' key.
A
Anonymous
Just start mashing buttons....this happened to me and after a moment of panic...it worked!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 04, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
189
Points
Its on the bottom of the of the mp3 player near the headphone jack. Make sure that the switch is on the left of the groove.
3helpful
2answers
I can't my samsung yp-u2j in my pc an i already
You need to upgrade your player’s firmware if you experience any of the following:
  • When your attempt to use the player, the Found New Hardware bubble appears and then flashes between several messages including MTP Connected, Don't Disconnect, MTP Device found, MTP Device may not work properly, or There was a problem during installation.
  • The player constantly appears and disappears in Device Manager or appears in Device Manager with an exclamation point indicating an error.
  • Your computer sounds the connecting and disconnecting chime when you connect the player to the USB port.
  • The player does not appear in My Computer.
  • Uninstalling Windows Media Player 11 and using Windows Media Player 10 corrects the issue.
  • When you use the player on another PC or laptop, it works flawlessly.
  • Your player was working properly with Windows Media Player 10, but you’ve recently upgraded to Windows Media Player 11 and your computer no longer detects it.
  • Go to Samsung.com, enter in the model u have in the search area and then go to support, this should fix the problem!
How do I charge Samsung MP3 player Yp-U3 Samsung YP-U3 MP3 USB port not connected to the computer
The player needs to be charged via the USB connnection on your PC. If it doesnt fit, try the USB ports on the back. If its not working/not charging, please test the MP3 player on another PC.
2helpful
Occuring the problem when turning on with the title"bulding eror"
Click here for Firmware Update from samsung.com
Here is the instruction for updating the firmware:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port(Hold down the play button while you connect the device, you should seea message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message"Initializing" on YP-U2J Updater, you can now remove your hand fromplay button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUSTdisconnect the Mp3 player and turn it on. You will see a 20% messagefor about 50 seconds and it will be restarted automatically.
4helpful
My mp3 YP-U1 is cannot read in my computer pls. help me :(
Device is charging once connected to USB-port.
Is recognised by the computer but cannot be accessed.
4helpful
2answers
Samsung YP-U2 & Windows Media 11 on Vista Home Premium
CLICK Here to Download : Firmware Update
This error is common with Windows Media Player
Here is the instruction:
Update: Pleasekeep in mind that if you sync your Mp3 player with a computer that hasa Windows Media Player 9 or 10, you should do these steps again
4helpful
YP-U2J - Need download - Didn't come with CD
In case you have a problem to connect your Samsung YP-U2J Mp3 player, you should update Firmware to get it working. The new Firmware may be downloaded from Samsung.com.
In case u have WMP 11 and player not working, this error is common after installing Windows Media Player 11
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Mp3
Follow these steps:
Cannot use my player-device manager problem/deleting files
This error is common after with Windows Media Player 11
1helpful
YP-U2JXB & YP-U2JZW Won't sync...Help!
Error C00D1236 virtually always indicates one of two things:
1) The device is trying to sync hidden files--are there any?
2) There is licensed media that is being synced, and the license is either corrupt or has expired. If you have any licensed media, then try going back to where you purchased it (in an iTunes-like music management program? In WMP?) and refresh/renew the license.
The bad news is that until C00D1236 is resolved, you can't sync your device. frown.gif
You can bypass syncing, and directly transfer files, In my computer, the mp3 plaer will be shown as a drive.
Now if one of the two solutions above is not feasible for u, try this:
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
