I was enabling android device manager and accidently locked my phone I tried temp password and it won't work how do I unlock my phone?
SOURCE: SIM UNLOCK CODE
*2767*688# not working with my E900 ,
Error = Incorrect entry
may be it worked on ur cell not mine ... anything updated about rest your SIM lock ? :(
E900
SOURCE: bb password
Enter invalid password 10 times, and your blackberry will reset it and prompt to set new one .
SOURCE: my daughter locked her cell phone up by accident
the default is always one of these code try them all the last four digits of the phonenumber last programmed in the phone aka your number or 9999,1234,4321,0000,1111 if none of those work you can go the retail store for a flash they hook it to the computer and push software to the phone to correct the issue it takes five mins and its free its a common issue for them to correct if you change your lock code from the default in the future always set up a dummy contact with it in there so that you can easily look it up also please vote for me I'm trying to work my way up to expert level and I cant without your vote please
SOURCE: how to unlock the android lock
here that is not a problem follow the steps below.
If you cannot remember the passcode, you will need to restore your device using the computer with
which you last synced it. This allows you to reset your passcode and resync the data from the
device (or restore from a backup). If you restore on a different computer that was never synced
with the device, you will be able to unlock the device for use and remove the passcode, but your
data will not be present
Follow the steps that i have outlined below. If this does not completely help your situation
please let me know and i will be glad to assist you.
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the
following:
If you can't unlock IPod using either [the code or connecting it to the computer you use to
manage its songs. . .
Plug the iPod USB cable into the bottom of the iPod Nano.
Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer.
Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a
PC.
Click on the name of your iPod Nano under the "Devices" list in the iTunes window.
5
Click on the "Sync" button to establish a connection between your iPod and the computer.
6
Click on the eject symbol next to your iPod's name after the syncing process has finished.
7
Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal
features again.
if that does not work you can restore your iPod to factory settings using iPod Updater. Please
note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
Apple also notes that company "representatives cannot unlock an iPod if you forget your
combination. If you can't unlock your iPod and you don't have access to the primary computer,
your only option is to restore the
IPod, which will erase all music and data."
If you need further assistance please feel free to follow up with a comment and i will be here to
assist you. If this assisted you please feel free to rate the comment. thanks and have a great
day. -Midwest-tek
SOURCE: imaging devices not showing up in device manager
Did you do a "scan for hardware changes"? Go to your laptops website and download driver, install. COLD-START the machine and look in Device Manager> Imaging Devices is it there?
