SOURCE: loud clanking noise in dishwasher
Most likely the motor as food caught in the sump would not make a noise you described.
http://tclaundryrepair.com/home
SOURCE: my Nordic Track E 4400 treadmill sqeaks loudly when in use
Hi again, OK thanks, The belt slides on a track and can get debris or other things that stick and is probably causing the squealing. There are belt cleaners and dressings and lubricants but the best place and the best product for your treadmill can be found at this site:
www.TreadmillDoctor.com They offer many bits of advice and how to on many different kinds of treadmills and can tell you how to clean and apply their product. Good Luck to you, this should Fixya!
SOURCE: My 2004 F-150 2WD is making a clanking noise on front left tire
The sway bar linkage probably came undone on one of the sides. Wikipedia has a picture of what your sway bar linkage may look like:
http://en.wikipedia.org/wiki/Sway_bar
That is a picture of a Porsche sway bar, but the idea is the same. Make sure all bolts are tight and that one end is not missing the linkage that connects it to the spring/strut. The grinding of the brakes may be the sound of the linkage piece touching the rotor. Sway bar is a logical solution to both issues.
If that doesn't fix the issue, put the front end of the truck on blocks or jack stands and have somebody wiggle the tire up/down and side to side while you inspect the mechanical components underneath. Other things to check may be the ball joints, tie rod ends and suspension bits.
SOURCE: I have a Nordic Track EXP 1000X treadmill and the
Probably 85% of the time, it's the sensor.
1. remove the screws from the bottom of the enclosure case. 2 or 3 in the front and 1 on each side
lay it back down, and power it up, and actuate your incline. watch the end of the motor, to see if the shaft is moving. It probably IS turning but only a little bit. NOT enough. In this case I'd say it is the sensor.
2. Unplug the unit of course.
3. the incline motor is in the middle of the pack,..you'll see a black tube looking thing sticking up.
4. on the bottom side of this, you will see,..or feel for a black square sensor attached to bottom of the motor casing.
5. follow the wires and unplug this.
6. pry it off with a screw driver. Remove incline assembly, if you cannot reach it.
7. replace sensor and try it again.
if the MOTOR does NOT turn when using the incline buttons, the problem backs up to possibly a bad control board. or a bad motor on your incliner, however, i'd say that's the last thing to go.
Order of failure: 1. sensor 2. control board 3. motor.
good luck
SOURCE: Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
o The Nordic Track C2050 allows users to change the incline of the treadmill with a simple touch of a button. This treadmill features both increase and decrease buttons for the incline. The incline of the machine will change by .5 percent every time the buttons are pressed. With each press on the incline buttons, the machine will take a moment to actually reach the incline setting that was just selected.
Capacity of Weight
o Users who are larger than or weigh more than the average person will be pleased with the added capacity of weight that the Nordic Track C2050 allows. Unlike most treadmills in its economy class that only allow a weight limit of 200 to 250 pounds, this model lets users who weigh as much as 300 pounds use the machine safely. Larger people can get the benefits of a cardiovascular workout on this treadmill without worrying about damaging it.
Heart Rate Measurement
o This Nordic Track model allows users to measure their heart rate. All the machine requires is for users to place their feet on its foot rails and grasp the metal contacts with their hands. The Nordic Track C2050 then works to determine your pulse, and the symbol of a heart will eventually show up in the display. After a couple of dashes show up, your heart rate will be displayed. Users who want to be certain of getting an accurate reading should ensure their hands are clean when gripping the metal contacts.
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Treadmill manufactures publish user's guides that contain running deck incline operation procedures and warnings. Typical guides include weight limits and conditions for use. Most treadmills are designed to manage up to 250 pounds of weight. Operating the incline with excessive weight on the deck or cycling through numerous incline setting in succession can tax the incline motor. In time, the normal sound of the incline motor may become louder when the feature is used inappropriately.
