Mitsubishi WD60737 Logo
Maria Casias Posted on Feb 19, 2017
Replaced chip on a 60" Mitsubishi model WD60737 no picture at all now. Before it had a picwith white dots now no picture.I have been searching for a picture of where the accessory plugs go and unable
5 Related Answers
Anonymous
  • Posted on Mar 20, 2010
SOURCE: developing white dots
white Dots appearing on Mitsubishi DLP 1080p. What causes this?
Anonymous
  • 760 Answers
  • Posted on Aug 23, 2012
SOURCE: I need the shematics to install A DMD chip in my Mitsubishi Model WD-C657
When you take off the back cover you are pretty much looking at the chip. Right in front of you in the middle of the light engine is a little fan.
Remove the fan and you will see a big metal heat sink / shield. remove the sheild and you will see a circuit board. in the middle of the board is the dmd chip.
chan_kurt_a
chan_kurt_a
  • Posted on Dec 02, 2012
SOURCE: we just replaced the DLP chip in our mitsubishi 1080P tv because we had white spots all over the screen. Now after replacing the DLP chip we have no picture at all but we have sound. Help?
Likely you either forgot to reattach your color wheel ribbon connector, or have it on upside down. It's the tiny ribbon cable behind your circuit board that will come off as you pull the board away from the DLP chip.
Anonymous
  • Posted on Jan 03, 2013
SOURCE: +little white star like dots
little white dots
terrydovre
Terry Dovre
  • 195 Answers
  • Posted on Jan 31, 2015
SOURCE: How to replace chip on Mitsubishi tv to fix white dot problem
Here's a link on to replace the chip on the DM board.....tks.....https://www.youtube.com/watch?v=JgiZdc4kZDw\
What is the correct part# for a DLP: Mitsubishi WD60737 60", Serial#139599 Made June 2009?
If your set worked well (no lines, maybe only white or black scattered pixels) before you replaced the DLP chip, then your problem could be that the DLP chip did not get seated properly or the cam screws were not tightened enough after replacing the chip. The DLP chip must be seated properly in its socket or else line and column lines will be seen. There is also the possibility that the DLP chip is defective or suffered static damage while being handled during the installation. Hope this helps.
Wd60737 mitsubishi 60"
how long has it been since you replaced the Lamp in the unit
MITSUBISHI 60 INCH PROJECTION TV WITH LITTLE WHITE DOTS ON SCREEN
You will need the DLP chip replaced. I do not recommend trying this on your own on a Mitsubishi. You need a technician who has extensive Mitsubishi experience to replace that chip(if it is available for your particular model) If the chip is not available for your particular model, it means replacing the light engine.For that cost I would update to a LCD or LED TV & come out ahead.
If you want an idea what it costs to replace the DLP chip (if avail for your unit) contact a local servicer & see what they can quote you over the phone. Be sure you are sitting down.
Considering the age of your unit I would be looking at an LCD or LED flat screen.
3helpful
2answers
After replacing the dlp chip in my mitsubishi tv there are vertical lines on the screen. any ideas?
i had the same lines on my 65' mitsubishi tv after replacing the DLP chip. after going back over everything i realized that the casinf that holds the chip in was not in the lock position. i took the chip out and replaced it then turned the little locking mechanism to the locked position. now my screen is perfect. hope this helps.
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
8helpful
3answers
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
7helpful
White dots are showing up on the screen. They are multiplying quickly. I was told to clean the filter but that did not help. The lamp is less than a year old. Nearest dealer is 2 states away. How can this...
This problems is the tv Projection Light Engine design flaw with it IC chip.These problems happen to many models of it DLP tvs Big Screen 60 and up.Mitsubishi,Samsung,Sony,Toshiba all used the same IC chip on their 60 and up on their DLP tvs Big Screen.Tries make deal with Mitsubishi help u split the cost of repair the tv Projection Light Engine by replacing the IC chip or replaced the entire Projection Light Engine system.This problems is not new,been going on for a few years.Many people when on Youtube **** about this problems with white dots showing up on their tvs screens and multiplying rapidly.
13helpful
2answers
Developing white dots
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
