Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
