Question about GE Profile PFSF6PK Bottom Freezer French Door Refrigerator
Loud buzzing/rumble when running
I have a ge profile, bottom freezer, french door refrigerator that is less than a year old. In the past month it has started making a terrible loud "buzzing" noise whenever it runs--sometimes so loud it drowns out the tv in the next room. repairman came and of course it made no noise...also seems to run ALL THE TIME! ....It didnt do this in the beginning, just the last few weeks. It has almost a shudder effect to it and is very irritating.....most dissatisfied....
  • fraleydj Jul 22, 2009
    model # is PFSF6PKXABB
  • Mike Smith
    Mike Smith May 11, 2010
    Sounds like a relay on the main control board is bad . Should replace the board . No model number , can't give you a part number .
    Scholar:
  • 42 Answers
Try this website "appliance partspros.com" You enter your model numer and the have compete breakdowns with pistures and how too instructions. the best part is if you join the websites blog......there you ask questions and an expert appliance reapir person sends you a reply. I have used the website for a few years and have never been steered wrong.
Posted on Jul 22, 2009
  • Keith Hirsch
    Keith Hirsch Jul 23, 2009
    If you think the control board is bad it can be replaced. I would need a model number though. there is a tag somewhere on the fridge, most likely on the rear of the frindge. I can do a little diggin for a solution for you if you can provide me with a model number. Better to find the actual problem than to go right out and buy a control board which may not be the problem
SOURCE:
French door refrigerator with bottom freezer. I do not have the ice maker connected. Makes buzzing sound, likely the freezer part is making the sound. The buzzing sound comes and goes and is louder...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 14, 2011 | GE Profile PDS20SFSR Bottom Freezer...
My Ge profile refrigerator is making a loud fan noise what is causing it?
Ice is built up and hitting the fan...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Oct 27, 2010 | General Electric Profile PFSF5PJX Bottom...
GE French door profile freezer is not freezing
Call the service company back and make them fix the problem, period. If they said that would fix it then they just bought the repair no matter how much it costs.
Jul 03, 2017 | GE Profile Bottom-Freezer Refrigerator...
Loud buzzing sound. warm fridge and freezer
Could not find info for the model listed could it be PFS22SBASS...any way the most common reason for your issue is the main motherboard part #WR55X10942
prices vary $180 - $200. The circuit that operates the compressor is most likely at fault. Most boards are located at rear of unit lower right, it controls all refer functions. Not hard to instal,l but due to the cost most electrical parts bought are not returnable.
Ric
Mar 09, 2010 | GE PFS22SBSSS Stainless Steel French Door...
GE PFS22MISBWW is a piece of junk
One doesnt like to hear it but possibly cut your losses and look for a less complicated fridge with minimum electronics.
Jul 21, 2009 | GE PDS22LBN Bottom Freezer French Door...
GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
May 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PFSF6PK Bottom Freezer French Door Refrigerator Logo
710 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Matt Sicignano
Level 1 Expert
