Need correct spark plug roughneck 2 E with Tecumseh engine OH 160170 170G need air filter manual can fuel filter be change? there is a number XL 2338 E
MTD Parts
http://manuals.mtdproducts.com > manuals
PDF
Remove oil drain plug and oil fill plug to drain oil. E. Install oil drain plug and tighten securely. F. Fill oil sump with recommended oil. See "OIL & FUEL.
8 pages
If your 8 hp Tecumseh engine on your snowblower is backfiring excessively and now won't start, there could be a variety of issues at play. Here are a few things you may want to check:
Fuel: Make sure that there is sufficient fuel in the tank and that it is fresh. If the fuel is old or contaminated, it could cause starting and performance problems.
Spark plug: The spark plug is responsible for igniting the fuel in the engine. If the spark plug is fouled or damaged, it could cause starting and performance issues. Check the spark plug and replace it if necessary.
Air filter: If the air filter is clogged, it could restrict the flow of air to the engine and cause starting and performance issues. Check the air filter and clean or replace it if necessary.
Carburetor: The carburetor is responsible for mixing the fuel and air in the right proportions for the engine. If the carburetor is not functioning properly, it could cause starting and performance issues. You may need to clean or rebuild the carburetor.
I recommend consulting the owner's manual or a qualified repair technician for further assistance in diagnosing and fixing the problem.
Wow! You've really got your hands full! 1) Verify the fuel pump is installed correctly and has power. 2) Verify the fuel filter is installed correctly. 3) Verify the spark plug wires are correctly installed. The number one reason for a car not running after an owner changes the spark plug wires - the wires were not installed to the correct cylinder.
if the engine slows then so will the pump... and so will the pump power.
engines are all the same and so just google "servicing engines"
an engine requires fuel - air - ignition and compression......
if your engine starts and runs then it must have reasonable compression so check / replace / clean the fuel and air filters... check the condition of the spark plug / clean it / replace it
after these basic checks you move onto measuring the compression and checking the carburettor which requires a level of skill you may not have
oh, check the oil too !
if you have a make and model of engine (not pressure washer) the manufacturer may have service kits and service manuals... briggs and stratton / honda / tecumseh (you'll be lucky) / sumec linhai
