Televison & Video Logo
Franco Mema Posted on Feb 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung led tv un55h6203af doesn't have any back light but has sound
Marvin
Level 3:
Top Expert:
  • Samsung Master 85,242 Answers
  • Posted on Feb 16, 2017
Marvin
Samsung Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29038345
Points
266281
If you have done the flashlight test and an image is present on the screen when the light is shined from behind then the backlight or the backlight regulator is defective, both should be replaced.
1helpful
I have a LCD tv samsung un32f5500 with a black screen. How do I check the LED strips in the TV ?
If you turn on your TV and you have sound but no picture, our LED back light might not be working. get a flash light. Hold the flash light up to the screen. If you see movement your LED back lights aren't working.
I have a samsung 55 inch led model number un55h6203af us01. Screen went black, but I can still hear sound. Did the flashlight test and I was able the see the menu. What needs to be replaced ?
There is no one answer that fits all any number of defective parts can cause this, supplest you have it diagnosed, do not start buying parts.
'pop' noise coming from upper left corner of a Samsung un55h6203af LCD TV. TV will not power on, but there are blue status lights on T-Con board.
I don't have the service manual for your set in front of me but I believe this sound is coming from the inverter board, the set takes 24 vdc from the power board into this board then increases the voltage to about 600 volts to drive the CCFL tubes in the panel, a guess would be you have a bad xfmr that is arcing on that board.
Samsung tv blacked out.
I do not know your TV model. If the TV is a LED TV, the problem is a defective LED back lights strip; If it is a LCD TV, the problem is defective back lights inverter module, or defective main power supply.
Samsung UN55H6203AF has audio but no picture. There is no visable damage to any of the boards. What should I check next?
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Samsung series 5. 5500 LED TV BLACK SCREEN
perhaps the backlight invertor driver circuit.
Samsung TV Repair Part Number Identification Backlight Inverters LED...
See where the wires from the long LED strips on the both sides of the screen lead you to.
does your model have separate board for backlight ? or is it integrated with TCON ?
1helpful
3answers
How do I fix my Samsung 40 LED TV that has sound but no picture?
Here is what to check when your TV is turned on, power light is ON, but no picture is seen or sound is heard:
1 - Be sure the component you are using (Xbox, Cable, SAT, ROKU) is turned ON.
2 - Check to be sure all cable and cords are securely connected to the TV inputs and component outputs.
3 - Make sure you are on the correct input as some TV's will show a black screen if there is nothing connected to that input.
4 - Unplug the input you are trying to use from the TV (such as an HDMI Cable) and plug it back in.
5 - Check for signs of damage on all cords and cables from the TV to all components.
6 - Make sure the TV is not in ENERGY SAVE MODE, press the button on the remote control to go back to normal mode.
7 - Unplug the TV for 10 minutes to see if there was a temporary one time issue with the TV.
8 - Disconnect the TV from power for 2 minutes, then when plugging it back in PRESS AND HOLD THE POWER BUTTON ON THE TV FOR 10 to 20 SECONDS to try and force the TV to reset.
9 - If after checking all these different issues, you may have a Faulty Power Supply Board, A Bad Capacitor on the Power Supply Board, Loose Wire Harness, or Loose Ribbon Connector in the TV itself.
10 - Most likely when a TV has the power light ON but NO PICTURE and NO SOUND, it is the Power Supply Board that has failed.
BTW, here are solutions for you to play iTunes movies on Samsung smart TV
1helpful
How do i input a wifi password to the tv model un55h6203af
guess you may find some tip on onboard user guide - look in menu, or download manual from here
Samsung UN55H6203AF Manual
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
