Crafts & Hobbies Logo
Ann Worley Posted on Feb 16, 2017
I want a printable manual for my cricut/explore air 2 where do I find one?
Page Gettman
Level 1:
  • Contributor 30 Answers
  • Posted on Mar 16, 2017
Page Gettman
Contributor
Level 1:
Answers
30
Questions
Helped
30148
Points
48
Here is a link to the Explore manual which has Air sections in it. I didn't see any reference to "2" so I'm not sure it's what you need, but check it out!
Cricut explore air 2 clamp A replacement
what car or truck is this, and what is a CRICUT
we can't see what you see , it must be told.
or show photos. then we can play that game.
2answers
My cricut explore air 2 will not load my mat, what could be the problem?
Cricut Explore Air 2 helps in cutting the beautifully intricate designs using the compatible cutting machines. However, in some situations, you can get the problem where you will not able to use the mat. In this situation, you first make sure you are following the right guide to load the mat, check if the mat is compatible with your Explore Air 2 machine, or your device is not facing any problem.
To get rid of this issue, you have to reset all of your devices and set up the machine once again. Also, check if the mat is not damaged, refer to the Cricut crafting guide for using the mat, use the compatible mat, and more. You can also connect to the Cricut customer support team to get more info from professionals to resolve the issue.
My computer can't find my cricut explore air. I haven't used it for awhile. The computer makes a noise when i plug into the usb port but still cant find it
Ensure your Cricut Maker or Cricut Explore machine is powered on and within 10-15 feet of your mobile device. ...
Open Settings > Bluetooth.
If Bluetooth is off, tap it to turn it on.
I have a cricut air2. I keep getting error code -44. Yesterday there tech had me clear my history including cookies and cache. It successfully cut once. Today, I keep getting the error.
why not ask them, it is there baby, we do not make or sell them.
what is this beast.?
it is this Vinyl , label maker printing machine can do iron on labels too.
so what is it connected to, it PC? what PC?
did you read the manual first.
https://learn.cricut.com/explore-air/manuals
did you call them for help or join there help forum.
here
https://help.cricut.com/hc/en-us/articles/360009381714-How-do-I-create-my-profile-in-the-Cricut-Community-
Will cricut explorer one run on a dual core computer
Ask the maker.... "Contact us" on the website:
https://shop.cricut.com/en_ca/machines/cricut-explore-air.html
"Contact us" is way down on the bottom in the small print. Good luck.
Top Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
