Hyundai air con has been working well until today when I turned it on, about a minute or 2 cuts off and throws fuse switch off.test button turns power on for a sec0nd then system is off again
SOURCE: air conditioner
check if the compressor is engaged...if not, check if there is refrigerant in your system...
there is a pressure switch that would de-activate ur compressor when low on refrigerant..
tnx,
drcool
SOURCE: hyundai accent, location of fuel cut off
hi from uk location of fuel safety shut off valve/switch on uk r/h drive accents is on the engine bay bulkhead in front of drivers side it is a square box with red rubber top press button may be on opposite side on l/h drives ? if activated? just press button till click ? to reset these normally only cut off on impact ? to stop elec fuel pump continuing delivering if involved in an R.T.A fire prevention
SOURCE: Audi A3 Air Con Cut out
Happened to me too, when the ECO light comes on automaticly (and it only blows hot air) it means it's simply broke.
I don't know the exact production date of your car, but there is/was an airco-related dealer recall for some cars, so just contact your dealer and have it fixed, but don't forget to mention the recall (it might save you a lot of money when your warranty has already expired).
SOURCE: Air con hissing noise from vents
Strongly suspect the AC system has sprung a leak somewhere and the refrigerant is 'low' - the 'hissing' noise you hear is normal when the system is 'undercharged.' Solution is inspect the system & repair the leak. If it turns out there is NO leak, then the problem is either at the compressor (low head pressure) and/or the expansion valve at the evaporator.
SOURCE: 03 hyundai sonata air bag light stays on
I read on another site to check the "yellow" connector under the passenger seat. Connector ncould be loose or wires that go in the connector may be loose.
