First turn ON your bluetooth on phone, then hold on/off button to turn ON Jabra headset for 5 SECONDS, then vill light hold ON (NO BLINKING) and then find it on your mobile phone....
1. Put the headset in pairing mode • Make sure the headset is off . • Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
hold down the button till the light turns solid blue, then let the phone already in bluetooth mode find the jabra, it will ask for a password, enter 0000
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Go to this site, and it will walk you through each step to connect your
particular Jabra headset with your cellphone. Choose the headset, and
then at the next page, choose your phone. Moving your mouse over each
step will change the picture to what you should be seeing on your phone
at each step. http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Make sure the Jabra headset is set to pairing mode, otherwise the phone cannot find the headset. The manual should have instructions to set the headset in pairing mode. While the headset is in pairing mode, have the G1 search for the headset (Settings > Wireless Controls > Bluetooth Settings). When it finds the headset select it and type 0000 for the PIN code.
First make sure your bluetooth and your phone are fully charged. Next press the on - off button in the middle of your bluetooth until it is a solid blue color. If it is flashing it is not in the pair mode. Just hold it down until it is a solid blue light.
Then set your phone to the pairing mode following your phones set up bluetooth instructions. Select the discover, search, or add function on your phone. Your phone should find the bluetooth device and ask "do you want to pair with it?" Accept by pressing yes or ok on the phone and entering the passkey or pin # of 0000 or 4 zeros.
Your phone should confirm when pairing is complete.
I discovered that I was not holding the on-off button down long enough for my bluetooth to reach the pairing mode and give me a solid blue light.
I hope this helps as I know how frustrating this can be.
7. Pair it with your phone
Before you use your Jabra BT125, you need to pair it with your mobile
phone. (Follow step 1-4 in fig. 3).
