SOURCE: navman 4500 fish finder w/transom mount transducer
I finally got an email reply from Navman. If the unit is less than two years old (mine is not) they will repair it. If it is over two years old, or if you can't prove that it is less than two years old, you can ship it to them and they will repair it for the low, low price of 355 US dollars.
Pretty nice of them since it appears these units are highly problematic isn't it? I am wondering if they guarantee their fix, or just have you on the hook for another 355 dollars later.
Good Luck Everyone,
Walt
SOURCE: I have an old Marinetek
Unfortunatly that transducer will not work on the new unit. The sonar sensor is not compatible with this transducer and I would doubt it would even match up to the plug in the Garmin. These units are very propriatory and you will have to use the transducer that came with the machine or one that was specifically designed for the sonar unit. The transducer for your newer unit should be able to mount flush on the hull without having to pull your boat out of the water. These newer units have the capability to see through the hull without having to mount them externally.
Pekka, Transducer and cable at links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
FISH 4430 Options Navman Marine
Navman Transducer Accessories eBay
Amazon ca transducer
