It helps a lot if when you post questions you include what year make and model vehicles you're having trouble with so the answer can be vehicle specific. In general what you were told does not make sense. That cable or linkage puts the transmission in gear. Park, reverse, neutral,ect. If the engine speeds up when you push the gas pedal, but the car doesn't accelerate in drive (or when in drive the engine revs up but the car doesn't accelerate) you have a transmission problem. Start by checking transmission fluid level, this with the engine running at normal operating temperature.
Linkage cable only changes ratio selections
if it is faulty , it will be stuck in one gear
the reason it is not accelerating is because the accelerator pedal and the throttle control are not communicating with each other
run the fault codes to check which sensor is faulty or if any other sensor is responsible
SOURCE: how do I remove and replace the steering column of 1992 ram 250 v
remove coupling from top of steering rack ( make sure you mark postition of coupling first with centre punch so the replacement will be in the same position)
remove covers from steering column and ignition + anything else attached to column. good luck
SOURCE: gearshift in truck is not shifting the
You'll need to try and narrow it down. You can undo the shifter cable from the gear shifter and from the trans it's self. See if it moves freely. Check to see if the lever on the side of the trans moves also, it will have more resistance(be sure to block the wheels and set the parking break). Also check movement for the gear shifter it's self.
Report back with which one is bound up, so we can further asisst you!
SOURCE: transmission shift cable
im working on one now, i just used a flathead screwdriver and lightly pryed it loose, it work and with no damage to the shifter or cable.
SOURCE: My 1992 ford econoline van is having problems with
see if the nut on the transmission came loose and let it slip
SOURCE: 1987 dodge ram van STEERING COLUMN
to whom this may concern did you find a steering column. Are you replacing it in a 1987 dodge pick-up
MAKE SURE THE VEHICLE'S ENGINE IS OFF AND IS BLOCKED TO PREVENT ROLLING ON SOME/THING/ONE!!!!!;BEST TO DO THIS WHEN UNDER A LIFT AT A SHOP !!!!!! (1)if the steering is locked,it won't shift. (2)if steering's unlocked but still won't shift,have someone follow the linkage from the steering column to the end(transmission)something may be obstructing its movement.(3) disconnect linkage from transmission end(where linkage connects to transmission) and see if you can shift it with,without destroying spline on shaft,a pair of vise-grips; if there's now movement of the shaft,it's in the linkage BUT if not,you may have internal problem(s) in the transmission itself. NOW,ALL THIS IS IF THE TRANSMISSION WORKS ON MECHANICAL LINKAGES AND NOT VACCUM ACTIVATORS. Please do your checking it out with help by you and use utmost safety!!!!!.
