SOURCE: external dvd re-writer
Well you need to go to the website of the DVD manufacture and get the vista drivers for your device. Vista does not have native support for most hardware, and very little backwards compatability. I wish you success on finding the correct driver for your device. Thank you, Shuttle83
SOURCE: WANT TO INSTALL LG DVD SUITE
Hello there.thank you for contacting us.i mentioned the cd key for power dvd version 5.0.iam sure it works out.enter the cd key present in the quotes.thank you again.
"mv46884891275875"
SOURCE: HELP!!!!! : "Not found CD/DVD Writer driver"
This could be due to a common issue. I would suggest you try this method first.
The following is a link to the Microsoft documented solution for issues with DVD/CD drives, explaining a step-by-step procedure. In the event that the first process, which is automated labeled "Fix It" does not solve your problem, please continue to the end of the document.
http://support.microsoft.com/kb/314060
After completing this procedure, please let us know if you are still experiencing any issues by posting a comment. If this information was helpful, please take a moment to rate the solution. Thank you
Testimonial: "thanx"
SOURCE: LG GP08 - SOFTWARE NOT WORKING
you must to upgrade your cyberlink, because cyberlink DVD8 can't read dolby surround digital audio.. but, that's not free.. you must to pay that... or try to install cyberlink DVD10.. that's so usefull, and can read dolby audio.......
SOURCE: I have an LG GP08NU40
Hmm, it seems that I have had a similar problem with my own dvd burner. Seems that the Laser used for DVD burning is broken or not working properly or you just need a firmware upgrade of your external DVD writer (you did mention reinstalling software, not firmware please clarify which one of the two it was).
OVERALL:
In case the hardware misbehaves - Get a cotton swab soak it a bit in alcohol and try to clean the laser eye-lens inside the drive that reads/writes on the disks. It is usually located when you open up the drive. *NOTE: dont use too much alcohol and let it dry completely before using.
In case there is a software issue - Download the latest firmware for the specific LG multi drive burner or ask more details/user manuals on the product on the official support page HERE. NOTE THAT this product is discontinued.
