Radio Communications Logo
j
julie hall Posted on Feb 12, 2017
How do i open my nexbook?it it has but will not opencharged
My son has a nexbook 11A he will be using it and the screen goes black & wont come back. He restarts it and it works for a while but keeps blacking out. is there a way to fix this?
The troubleshooting of any computer involves resetting it back to factory settings. That means all data must be conserved if you want to be able to use the data, pics etc again. After backing it up you can perform a factory reset on it to see if the problem goes away. There are risks involved in this process. You may end up with a brick. The reset procedure is well documented on you tube.
I just bought a notebook ares 8a, wich sucks. Nothing updates continues to say download pending, and the one game my daughter downloaded said the same. Deleted tried to reinstall, still pending. Why
Pauline, it is not a notebook that you purchased from Walmart. It is a Nexbook, and it is an Android Tablet. This Android tablet has only 1 GB of RAM memory, and the number of apps you can load into this tablet is limited. It is not suited for games. This tablet is more for casual Internet surfing, Youtube, etc. You pay for what you get.
I got a nextbook NX16A10132s ps, for Christmas and I don't have the receipt for the activation code. What can I do
if bought with credit card you can go back to store for a copy . nexbook can give new code.
Hello I got this nexbook aras 5 today and it is taking a long time to check for updates so what do i do
Get a faster internet connection, or wait it out. This shouldn't happen again after the updates are finally downloaded and installed.
2helpful
What will cause a sunroof not to close properly on a 2007 Milan
A lot of thing's , has sensors , switches , a control module , relay's etc....
The roof opening panel is an electronically operated panel that can be opened or closed by pressing a switch located on the overhead console. It also has one-touch open, one-touch close, one-touch vent open and one-touch vent close features.
Roof Opening Panel The roof opening panel assembly uses an integrated motor and module to operate the roof opening panel. The roof opening panel motor and module are installed new as an assembly. The roof opening panel is an electronically operated glass panel that can be opened, closed or tilted by the roof opening panel switch. Actuating the switch in either a forward or rearward motion supplies a ground to the roof opening panel motor/module. The roof opening panel has one-touch open and one-touch close features that are activated when the switch is momentarily pressed to the double detent OPEN or CLOSE position. These functions are controlled by the roof opening panel motor/module.
The roof opening panel motor must be initialized whenever the roof opening panel motor has been removed from the roof opening panel system, the roof opening panel assembly has been removed from the vehicle, a new roof opening panel motor has been installed or a new roof opening panel assembly has been installed.
Plus the mechnical parts of it .
Visual Inspection Chart Mechanical Electrical
  • Roof opening panel
  • Roof opening panel frame
  • Roof opening panel drain hoses
  • Roof opening panel lifter assemblies
  • Roof opening panel trough
  • Roof opening panel air deflector assembly
  • Roof opening panel seal
  • Roof opening panel shield
  • Battery junction box (BJB) fuse 33 (20A)
  • Smart junction box (SJB) fuse 12 (7.5A)
  • Circuitry
  • Accessory delay relay
  • Roof opening panel motor and module assembly
  • Roof opening panel switch
My son set a password on his nexbook and can;t remember it how can i reset it
you may have to restore it , go to youtube and post your problem , should be there
How do I connect my Nexbook 8 to the internet on my laptop
You connect your Nextbook to YOUR WiFI HOME NETWORK (not the Internet) FROM THE NEXTBOOK, not from the laptop. On your Nextbook, go to Settings then Wi-Fi. If your Nextbook is already connected to your WiFi home network you will see the network's name there and you are done. If it is not connected, a list of available WiFi networks appears. Tap on the name of your home network and it will connect to it. If your network is password-protected, you will be asked to enter it.
Nexbook
please provide actual brand and model # for better help
3helpful
2answers
What is code 14 on 03 zx636
Hi, here you go:
Service Code Problems
11 Main throttle sensor malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or short
13 Inlet air temperature sensor malfunction, wiring open or short
14 Water temperature sensor malfunction, wiring open or short
15 Atmospheric pressure sensor malfunction, wiring open or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor malfunction, wiring open or short
24 Speed sensor malfunction, wiring open or short
25 Gear position switch malfunction, wiring open or short
31 Vehicle-down sensor malfunction, wiring open or short
32 Subthrottle sensor malfunction, wiring open or short
33 Oxygen sensor #1 inactivation, wiring open or short (Equipped Models)
34 Exhaust butterfly valve actuator sensor malfunction, wiring open or short
35 Immobilizer amplifier malfunction
36 Blank Key detection
39 ECU communication error
51 Stick coil #1 malfunction, wiring open or short
52 Stick coil #2 malfunction, wiring open or short
53 Stick coil #3 malfunction, wiring open or short
54 Stick coil #4 malfunction, wiring open or short
56 Radiator fan relay malfunction, wiring open or short
62 Subthrottle valve actuator malfunction, wiring open or short
63 Exhaust butterfly valve actuator malfunction, wiring open or short
64 Air switching valve malfunction, wiring open or short
67 Oxygen sensor heater malfunction, wiring open or short (Equipped Models)
83 Oxygen Sensor #2 inactivation, wiring open or shout (Equipped Models)
94 Oxygen sensor #1 malfunction, wiring open or short (Equipped Models)
95 Oxygen sensor #2 malfunction, wiring open or short (Equipped Models)
Top Nextel Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Nextel Radio Communication Expert? Answer questions, earn points and help others
