My camera casio exz75 doesnt want to hold a charge
Everytime i connect it its suppose to have a red light tht stays red but now everytime i try to charge it instead of staying red the light now blinks! which means its not charging!
This often means that the battery is bad. It's a good idea to only charge the battery as long as is necessary, and to then remove the battery shortly after it is finished charging. This helps prevent from an over-charge on the battery which can damage the battery life.
Charge your battery with an external power supply or a car battery charger for like 10 seconds (1 ampere will do the trick) by connecting the + and the - of the battery to the + and - of the power supply.
Now insert the battery in your normal charger. ìf it will still not charge do it again for 10 seconds.
Battery problem. Well known problem with the NP-20 battery. It can be repaired by connecting it to ~4-4.5V 1-1.5A for about 5-10 seconds and then charged normally with the charger. Of course a new battery will be better.
Depending on where you are and if it is still within the new warranty period or not depends on how long or how much it will cost to replace the battery. Call the Distributor for Casio in your State or Country and they may even send you one out Free Of Charge.
truthfully you dont even need any software to run the camera just use photoshop and just upload the pictures from the cameras folder copy and paste from the folder
The battery isnt charging and i also get a red flashing light. I've tried to turn on my camera and it wont turn on. has anyone found a solution for that??? Please email me at [email protected].
