Coffee Makers & Espresso Machines Logo
Linda Mohr Posted on Feb 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How much apple vinegar do I add to 4oz of water
deton8 von Splosion
Level 3:
  • Master 3,342 Answers
  • Posted on Feb 12, 2017
deton8 von Splosion
Master
Level 3:
Answers
3342
Questions
6
Helped
928474
Points
54123
Hello Linda Mohr,
1/2 White vinegar +1/2 water (wait 30 minutes = success.
This from the HUFFINGTON POST...
Fill the coffee maker's water chamber with equal parts white vinegar and water. Using a paper filter, allow to brew until half the chamber is empty. Turn the coffee maker off and let it sit for 30 minutes, then finish brewing. Rinse the machine by using a new paper filter to brew a pot of clear water.
I would stay away from apples.. grapes,
wine & balsamic vinegars...
I like a strong cup of coffee... but wit a
COFFEE FLAVOR (nothing else).
If you can NOT find WHITE VINEGAR use a commercial
POT CLEANER...
Carnac the Magnificent
What would be the recommended daily dose of apple cider vinegar?
According to eMedTV, no set dosage of apple cider vinegar has been proven to be safe and effective. However, people often use doses ranging from a teaspoon to a tablespoon taken with a full glass of water up to three times per day. The acidic nature of apple cider vinegar can cause the enamel of your teeth to become eroded, irritate your throat or interfere with blood-thinning medications, diuretics or insulin. Drinking too much vinegar could cause your potassium levels to fall too low, and drinking straight vinegar could cause damage to your esophagus, according to a review article published in "Medscape General Medicine" in 2006.
Jan 21, 2018 • Dishwashers
How do I convert 5% Apple cider vinegar to 2.5% Apple cider vinegar thank you
I went google and typed in--- changing the acidity of vinegar
the first site --testing acidity of vinegar is informative (www.culturesforhealth.com>testing acid)
there are lots of other sites and from one of them you will get a procedure on how to reduce the % to what you want
It is just not a matter of adding water but a process of reducing the PH value of the acid
Happy experimenting
Mar 13, 2016 • Dishwashers
How do you remove calcium deposits?
A weak vinegar/water solution should remove calcium deposits. I either used purified water or I add a tiny bit of vinegar to the water when I use the humidifier to help prevent calcium deposits from forming.
The mix of vinegar to water is up to you, but as a guideline, if you're smelling a strong odor of vinegar, then it is likely that your solution is too strong - try adding some water to it. Rinse with clear water afterwards.
Apr 14, 2015 • Humidifiers
2answers
What's your home remedies for hair? I use Apple Cider Vinegar Rinse. The acidity of apple cider vinegar does wonders to smooth frizzy hair, and as an added plus gives it a great healthy shine. There are...
Go to a craft store but a small bottle of glycerin.It's by the cake Decor.mix with a full bottle of water.Defrizz and be happy.use w hairspray to scrunch with your blow dryer to bring out curl or wave for volumizing affect.have fun......frugal hairstylist
Oct 11, 2013 • Dishwashers
No suction on my Bissell Ready clean carpet cleaner
After cleaning is finished, Rinse out any left over soap from solution tank.
Refill with two cups of cool clean water and add two tablespoons of apple cider vinegar Braggs works great run trigger until all solution is spent.
No more clogged jets. Hope this helps..
Jun 28, 2012 • Vacuums
Is it alright to add vinegar in the Kenmore front load washer. I find this removes smoking odors the best.
The answer is YES but keep in mind that like all Front Load Washing machines, use less vinegar than you would a typical top load washer. If you would usually use 1/2 cup of vinegar (4oz) try using half of that.
My keurig says I need to descale.How?
Descaling depends the size of the reservoir. I see the B60 but not the B66 at the Keurig site. The two units are apparently the same from searching the support side of the Keurig site: http://www.keurig.com .
For the Mini coffee makers, you use 20 oz of vinegar (2 10 oz cycles). For the larger Keurig units, it takes 48 oz of vinegar.
In either case, fill the reservoir with vinegar and put a large ceramic (12 oz mug for the mini unit) mug on the drip tray. Do not add a K-cup. For the B60 (and probably the B66), press the Brew button. Discard the vinegar after the cycle. Repeat the brew process until Add Water is indicated. Discard the vinegar each time. Then wait 4 hours with the unit on. Discard the remaining vinegar and rinse the reservoir. Fill the reservoir with 48 oz of water and brew several cups without a K-cup until the "Add water" message appears. Discard the water in the mug each time. Repeat the vinegar cleaning if De-scale still appears in the LCD. Run more water without the K-cup if you notice a remaining taste in the coffee after the rinse procedure.
For the mini, fill the reservoir with 10 oz of water, lift the Brewer handle and lower it after 5 seconds with no K-cup in the unit. Press the Brew button. Discard the vinegar after the cycle. After the first cycle, pour the other 10 oz of vinegar into the Cold Water Reservoir. Lift the handle and lower it after 5 seconds. Press the Brew button and wait until the light becomes steady. When vinegar starts to be dispensed, power off the unit. Wait 30 minutes. Then power on the unit and lift and lower the handle again. Then discard the vinegar after the cycle. Next run 4 rinse brew cycles with 10 oz of water each time. Discard the water each time. The unit should be ready to brew with a K-cup after the 4 rinse cycles.
I hope this helps.
Vinegar
Do not add anything to the tank.... Vinegar is corrosive and that would potentially be very bad.
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
